Question about Bosch DWM40L Miter Finder Digital Protractor/Angle Finder
SOURCE: My Bosch DWM 40L angle
Open the the moveable arm and make it straight (180 degrees) or in line with the other.Take the screw off of the black cover at the elbow (1 screw). Lift from the round part and lift off. Then loosen the two screw just inside the cover. This will allow the flywheel to spin and you should now get a read out. If the flywheel does not spin then you need to replace that piece. Gently tighten the two screws and put the cover back on. Hope this helps!
Posted on Nov 07, 2011
SOURCE: Bosch DWM 40L, Cannot seem to resetit,it reads
The first thing I would do is to replace the battery after cleaning the contacts thourghly. Hope this helps. Thank you.
Posted on Feb 24, 2011
Sep 06, 2016 | Sanyo DWM-1000 System
Jul 29, 2015 | Exercise & Fitness
Mar 14, 2015 | Hunter Dryers
Nov 24, 2013 | Jazz JDC27 Digital Camera
Nov 15, 2012 | 1991 Jaguar XJ6
Dec 28, 2011 | Wowwee Robopanda Robot
Aug 15, 2011 | Bosch DWM40L Miter Finder Digital...
Feb 24, 2011 | Bosch DWM40L Miter Finder Digital...
Feb 21, 2011 | Bosch DWM40L Miter Finder Digital...
Oct 09, 2009 | Bosch Water Heaters
Jan 26, 2014 | Bosch DWM40L Miter Finder Digital...
720 people viewed this question
