Apex Digital ADV3800 DVD Player/VCR Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vhs tape stuck in player also say's locked tried pw, still locked up - can't even get menu up.??
  • diskjock56 Jun 09, 2011
    could not pull this out of unit locked in
Azrael SRL
Level 3:
  • Apex Digital Master 11,800 Answers
  • Posted on Jun 09, 2011
Azrael SRL
Apex Digital Master
Level 3:
Answers
11800
Questions
0
Helped
2564643
Points
35672
The unit is locked because it has detected a malfunction in the tape mechanism - most likely the tape has been pulled out of the cassette and caught so it has blocked the capstans and the drum.
To fix that you will have to take out the caught tape manually: open the case, access the tape mechanism and start taking the the tape itself out by cutting it in small pieces with a fine cutter and pulling it out gently- if the tape is wrapped around some parts do not pull on it, it might bend the parts. Once all the tape is gone assemble the unit back, power it and immediately press the Eject button on the VHS section. Once the tape cassette is out wait for 30 seconds and stop the unit, wait another 30 seconds and start it again - that should fix it.
  • Azrael SRL Jun 09, 2011
    As i said you must open the case of the player and cut the actual tape that has been pulled out of the cassette.
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
My Panasonic VHS Player Model PV-V4020 is locked up so I cannot insert a new tape.
This will be some form of physical damage to the carriage mechanism, that holds the tape. Sometimes it's a simple thing like the flap getting stuck. But often it's a broken piece of plastic.
Power off when inserting vhs tape
I had this problem when copying an old family vhs tape. I had to unscrew the top of the magnavox to access the vhs tape. Then, I gently removed the tape and replaced the cover. After winding the tape back, I put it in the player and immediately pushed fast forward for about 3 seconds before hitting play followed by d.dubbing. I was able to make a copy of the tape and did not damage my original.
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
3answers
I have a Panasonic DMR-ES30V. I've only ever recorded from what I'm watching on the TV to a DVD. I now have a VHS tape that I'd like to record to DVD. I tried starting the dvd to record...
Most Combo Recorders (VHS and DVD) will prevent you from
recording a Copyrighted VHS tape program onto DVD.
Try recording a TV program onto your VHS tape, then
transfer it to your DVD and see if your new DVD recording
will work or not.
Tape stuck in vhs players
Yes you can cut the tape, remove it and then go to radio shack or walmart electronics dept and get some special vhs repair tape.
Top Apex Digital Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
