Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All of the sudden the remote control does nothing, won't work at all. What can I do?
Eric Sebasta
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 20, 2012
Eric Sebasta
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
614
Points
No it does reset everything by unplugging. It has SDRAM. It is how it remembers you channels if you leave it in your basement two years, then pull it out. I do not know how to do a factory reset... but this, isn't it.
Veril Gillette
Level 3:
Genius:
  • Master 1,126 Answers
  • Posted on Jun 09, 2011
Veril Gillette
Master
Level 3:
Genius:
Answers
1126
Questions
0
Helped
213114
Points
3124
Try to remove the batteries from remote, if that don't work, unplug main unit from wall for 40 Min., and it will reset back to normal.
Pioneer vsx-32 won't turn on with remote
Hi, since both remotes suddenly fail, I am assuming the problem is more than likely with the received rather than the remotes.
If you do wish to check your remotes, then point your mobile phone camera at the remote's Infrared lens and press one the remote's buttons. Your mobile phone camera is able to detect Infrared light and in case you remotes are working properly, you should see light coming out of your remote's Infrared lens.
Make sure that no direct sun light is on your receiver because that can effectively block out the signals from your remote controls.
Try the following method to reset your receiver. Unplug your receiver mains cable from the mains wall socket; power your receiver on by pushing the on/off button (nothing will happen obviously) and leave it like that for say 30 minutes. By that time all capacitors in your receiver will have discharged. Plug your received mains cable in the mains wall socket.Push the receiver's on/off button and see if it know responds to your remote controls.
If the problem still persists, you may have a failed Infrared receiver LED. That component can be found inside your receiver. It will take some basic elelectronics skills to get this component replaced. A service manual can help you. You can download it for free from this website: http://elektrotanya.com/pioneer_vsx-32_33.pdf/download.html
Good luck.
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
My RCA remote won't work with my JVC VCR/DVR
I recomend to read very well your owner manual and read the topis for Synch. see the section a( how to set up b( section troubleshooting.
if you donot have it download from www. retrevo.com
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
My RCA P60925BL won't turn on with remote or using the power button
Try by an other code for your device from the code list for your tV brand.
My magnavox tv was purchased in 2007, and now all of the sudden the remote won't even put the volume up or down and also can't change the tv settings with it,, it was working fine with the cable...
Most like the remote inner rubbers black dots tips of on those functions rubbers buttons are worn out and no more rubbers black dot tips left there any more to be connected make contact between the black dots tips to the remote PCB board.Or the remote CPU chip is shorted and dying,the CPU chip control everythings and remote devices are very dependent on it.Try website like Remotes.com to buy an original remote for the replacement.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
