Question about Honda Electrical Supplies
I have two Honda 2000i generators I usually use with a parallel device. When connecting the second one, its overload led comes on and it does not generate power. It starts and runs fine indepentently but does not generate power when tested with a small appliance.
Posted by gordont1944 on
scott sabella
    New Friend:
  • 70 Answers
The generators are not built to be used in this application
Posted on Jun 12, 2011
  • kwie2011 Mar 31, 2012
    They are made to use In parallel
Yamaha 2400IS Generator goes to overload when ie: 240 volt plugged in, or 700 watt angle grinder plugged in.
No idea but somebody else will probably come along with a better idea then mine, seems a lot of these generators have this thing installed on them (Has $25 hard start kit). Not sure what it does or how it works. Strangely enough you said you use it for 240 volt. Looked at the picture and didn't see a 240 volt connection.
If you are using the what look like the 120 volt circuits you can't over load the unit. Maximum current draw will cause it to go into protection mode and shut down the power load. The following is an exert from the owners manual which I got from Yamaha's site. Link at the end of this post.
Hope this helps
16
q
760-029
AE00788
Overload indicator light
The overload indicator light
comes on when an over-
load of a connected electrical device is detected, the
inverter control unit overheats, or the AC output voltage
rises. The electronic breaker will then activate, stopping
power generation in order to protect the generator and
any connected electric devices. The AC pilot light
(green) will go off and the overload indicator light (red)
will stay on, but the engine will not stop running.
When the overload indicator light comes on and power
generation stops, proceed as follows:
1. Turn off any connected electric devices and stop
the engine.
2. Reduce the total wattage of connected electric
devices within the application range.
3. Check for blockages in the cooling air inlet and
around the control unit. If any blockages are found,
remove.
4. After checking, restart the engine.
http://www.yamahamotorsports.com/assets/service/manuals/0/LIT-19626-01-23_1423.pdf
Jun 06, 2016 | Yamaha EF2400iS Portable Generator
Why does my Honda 2000i Generator run but produce no power?
Check to see if there is a breaker that has popped as a first diagnostic step
Oct 12, 2014 | camperpartsworld.com Honda Generator EU...
I have a Honda EB 7000I generator. It runs for 7-10 seconds then stalls. When it stalls the red LED overload light comes on. I just put a brand new Inverter in it. Since it sat awhile with a bad...
As silly as this sounds, Harbor freight toold generators by "Predator" will shut down if the generator is not on level ground, and the oil level is not at the desired level, crazy but there is an inbuilt oil level sensor. maybe this might be the answer. hope iy helps, good luck.
Oct 19, 2013 | Motorcycles
My EU 2000I ran my half ton AC unit for over a year. It now all of a sudden starts popping the 20 amp breaker anytime I turn it on. It only pulls 10 amps at startup. What's with this? Is it time to...
Make sure it isn't trying to start the HVAC with a locked compressor (IE it just turned off and is now trying to cycle on again) If it is shutting down due to low freq there is too much load for the HP the engine can deliver. That will cause too much current to flow and trip the breaker. Also be aware it takes 6 times current to start HVAC than to run it. How old is the generator? it may have normal engine wear and can no longer generate HP, Also when was it tunes up
Sep 30, 2013 | Honda EU2000i/Companion Parallel Cable/RV...
I have a Honda EU 2000i generator. With eco switch on or off the generator revs up every few seconds. If I turn the choke to half it seems to almost get rid of the problem. What can be causing this?
starving for fuel. the generator will always rev up when it is under a load or about to run out of gas. there will be a few adjustment screws on the carb... one for air and one for fuel. try increasing the fuel a quarter turn and see how that does
Dec 15, 2009 | Honda 3000 Watt Portable Generator
Honda 2000i generator need to replace power pull cord
take of cover where cord goes in watch direction and replace cord. wind up spring in right direction, test and replace cover.
Dec 09, 2009 | Electrical Supplies
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Sep 09, 2009 | Honda Electrical Supplies
E29 Trouble Code for a Honda Generator
Honda is pretty tight with the codes. You have to call a 'Authorized Dealer' to get it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 27, 2009 | Electrical Supplies
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
206 people viewed this question
Top Honda Electrical Supplies Experts
Sheldon Dedek
Mike
Marvin
Marvin
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
