Question about Samsung HP-R4252 42 in. Plasma HDTV
Hi I have a Samsung HP-R4252 42" Plasma HDTV. The
Posted by Lyle on
Chi Chu
  • Samsung Master
  • 8,457 Answers
Try website like Ebay.com to buy a refurbish tv main Tuner signal board.The part number it is on a sticker on the board,must take the tv aparts to read it.The fan itself buy it on Ebay.com too,or try website like Partstore.com to buy a part fan.
Posted on Jun 09, 2011
Bad picture on Samsung HP-R5052 50 in. Plasma HDTV
Hi there!
I suggest changing the screen , it is getting worn out
peace.
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
My tv won't turn on
Check and replace the man power regulator board as card basis. There is no repair to these boards of Plasma televisions. Replacing the power board is not a simple job. Check this link to get more details.
Samsung hdtv plasma ringing noise
the echo is probably a expanded stereo or something that you have turned on in the menu under audio. do yourself a favor,reset all your menu settings. the ringing,could be something more,coil on the buffer boards??? Check out http://www.shopjimmy.com/ they have tech assistance plus the best prices
1helpful
Where do I plug in headphones?
Looking at the specs for your TV, it does not appear to have the jack for earphones.
You will have to connect an audio receiver to your TV and use the reciever's jack.
Connectivity
  • HDMI ports qty4
  • PC interfaceVGA (HD-15)
  • Input/Output connections3 x HDMI (19 pin HDMI Type A) - Rear,
    1 x HDMI (19 pin HDMI Type A) - Side,
    2 x Component video input (RCA phono x 3) - Rear,
    1 x Composite video/audio input (RCA phono x 3) - Side,
    2 x USB (4 pin USB Type A) - Side,
    1 x Ethernet (RJ-45) - Rear,
    2 x Audio line-in (RCA phono x 2) - Rear,
    1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear
  • Video interfaceHDMI,
    Component,
    Composite
I Have a Samsung HP-R4252 42 in. HDTV Plasma Television and the picture is not showing. It does have sound but no picture. Is there any ease way to fix this problem??
sounds like the video cable is not in the right input.
or maybe you have to redo the setup and be sure the tv is set to the right video input . HDMI or component etc. I hope this helps.
Pink and blue horizontal lines running across tv when in hd mode
No, but it does mean you should take it to a reliable place and ask for a firm "Quote" and go from there.
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. [email protected]
Broken HDMI Port for HP-R5072
The HDMI input along with others is located on the a/v control panel of which would have to be replaced. I haven't seen an input jack yet with a part number attached for any model. I would suggest call a service center for a diagnosis.
Plasma
When you say "struggles to get a signal" I assume you are receiving HD programming over the air using HDTV antenna. If so, try to re-orient the antenna. Better yet, go to this website http://antennaweb.org
type in your address and it will provide you with the best antenna and antenna positioning based on your location.
If you are receiving HD programming via cable or dish, contact your service provider and they can best resolve your issue if the problem is beyond the loose cable connection in your TV's tuner input.
FixYa!
Samsung HP-R4252 42 in. Plasma HDTV Logo
Ekse
Demonic-2011
Demonic-2011
