Like a buzzing noise? Check valve where water lines connect at back will make a buzzing noise, if you only hear it when running hot water and not when running cold. Remove and replace it after shutting water off, and draining tank down. Be sure to shut off any hydro to electric element prior to draining.You can buy a replacement check valve, or just put a short 1/2" pipe nipple in there instead and reconnect your line, and refill it. noise should be gone .
