Question about Intel Motherboard
Computer wont boot and cant locate sata drive.
Posted by alarosa24 on
Anika Tech
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Anika Tech Support to give our clients the technical expertise IT Support including Desk Side Support, Remote Support, Project Management, Security, Business Growth and Customer service.
https://www.anikatechsupport.co.uk
https://www.anikatechsupport.co.uk/managed-it-support
https://www.anikatechsupport.co.uk/cloud-hosting-services
https://www.anikatechsupport.co.uk/projects-consultancy
https://www.anikatechsupport.co.uk/cyber-security-continuity
Posted on Mar 10, 2019
Ed Falat
    New Friend:
  • 5 Answers
Before you open the case, or the hdd drawer, dowload the UBCD on another working computer and install it to a cd or usb pendrive.
http://www.pendrivelinux.com/install-and-boot-ultimate-boot-cd-ubcd-from-a-usb-device/
Click on the HDD folder and use the utilities to detect the drive and it's condition, then, if no results, check that the data cable is seated at both ends and the power cable is also correctly aligned and seated. If you are using a sata adapter on your power supply, make sure no pins have unseated from the plastic assemblies.
Posted on Dec 31, 2014
  • Ed Falat
    Ed Falat Dec 31, 2014
    http://www.pendrivelinux.com/install-and...
Angelica Lynda Gozum
    Filmmaker:
    Uploaded 5 video answers.
  • 98 Answers
  1. You might try using a different power or SATA cable to the drive. One of them may be defective.
  2. If your BIOS cannot see it then Vista cannot see it.
    Check your BIOS settings....you might need to enable SATA in your BIOS
I hope this information will be helpful. Thank you for using FixYa!
Posted on Jun 09, 2011
HOW DO I FIX A EMACHINES G52W BOOT SEQUENCE AND SETUP SO I CAN GET TO THE INTERNET ?
I believe you might want to set the boot to
1 DVD (first)
2 SATA Drive (second) Maybe you didn't have this listed as 2nd.
If you have a disk in the DVD drive it will say press any key to boot from the DVD drive.
Oct 02, 2014 | E-Machines eMachines Desktop PC
Cant access HITACHI TRAVELSTAR 5K250 HTS542516K9SA00 160GB drive
If the drive cannot be accessed then the logic board on the hard drive is toast. U can remove the sata drive and install it into a working desktop with sata connections and see if the desktop recognizes it.
When installing on another computer, make sure that you are still booting up from the working sata drive originally there. If you change the bootup sequence to the allegedly non working drive and it does work you may corrupt the operating system in the bootup process. Just put it in there and see if the other computer boots up and recognizes it. Often if a hard drive is really bad the defective unit will prevent a good working computer from booting up at all.
Nov 22, 2013 | Fujitsu "HITACHI TRAVELSTAR 5K250...
My computer wont boot up
check your cables,your hard drive is not detecting
May 09, 2012 | Dell Inspiron 530 Desktop Computer...
MSI N1996 motherboard with 640gig sata drive / sata DVD ROM / NVIDEA Graphics card G7500 - wont boot up windows 7 even though i install new sata drive and try new installation it wont boot up! Pre...
hi there.
this is all the info i can find.plus try the link at the bottom might help you out some more.
If your computer blue screens when you turn it on, then loading in safe mode could help you get into your computer to sort out the problem. To boot safe mode in Windows 8: Hold Shift and press F8 upon startup to open Recovery Mode. Select See Advanced Repair Options, press Troubleshoot and select Advanced Options.
How to fix the blue screen of ***** - Cheeky Munkey
getting blue screen error Google Search
Nov 17, 2017 | Intel Motherboard
Computer doesn't boot 'no boot device available" it cant find the hardrive it says sata 0-none sata 1-none sata 3-none sata...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 17, 2011 | Dell (Y3392) 80 GB SATA Hard Drive
Boot problem with IBM xseries 306 - SCSI Drive and SATA drive os is on scsi drive and wont boot if sata is installed. how do i force machine to skip sata drive
I think first u disconnect ur all HDD to server. then u enable ur booting HDD or operating HDD...and setup again....
Another way: If u have original windows ..u can use windows recovery disk ...then recover ur missing file(kernel).
Thanks
Dec 21, 2010 | IBM eServer xSeries 306
My SATA HDD cant be seen and wont boot
In order to recover the data, you will have to obtain a disk utility such as 'Avanquest Partition Commander' (any version). Boot from the CD to see if the SATA drive can be "explored".
If so, connect a USB or eSATA drive and copy the partition to the external drive.
Other experts may suggest a different disk utility.
Nov 05, 2009 | Seagate Barracuda ST3500641AS 500 GB Hard...
Boot up error
You may have to open your computer and locate the hard drive. Trace the cable to see where it plugs into the motherboard. If there are other slots that it will plug into the motherboard, try plugging the hard drive into those.
If you have SATA plugins, it will be relatively easy to find a new port to plug it into. If you have IDE plugins, you may want to skip my solution and try other things first.
Apr 16, 2009 | Computers & Internet
Asus p5ld2-v motherboard
Har ikke sett manual ennå/ trenger også bedre bilde av
Aug 15, 2008 | ASUS P5LD2 Deluxe Motherboard
Intel Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
