Wall button light flashes and remotes won't work. I reset the opener by pressing the program button on the opener the wall button stays on steady without flashing and the remotes work. The problem is that this is an intermitant problem. When I attaempt to re-program the remotes the green button on the opener flashes repeatedly instead of once per the instructions.
Any ideas?
That's not a particularly helpful answer. What does one look for if the logic boar is failing? Is it owner repairable? Please provide more information. Thank you.That's not a particularly helpful answer. What does one look for if the logic boar is failing? Is it owner repairable? Please provide more information. Thank you.
You can't post conmments that contain an email address.
To program a new wall console for your Digidoor 3 to the receiver, follow these steps:
Connect the receiver to a power source and turn it on.
Press and hold the "Learn" button on the receiver for 5 seconds. The LED light on the receiver should start flashing.
Press and hold the "Learn" button on the new wall console for 5 seconds. The LED light on the wall console should start flashing.
Release the "Learn" buttons on both the receiver and the wall console.
Press and hold the "Open" button on the wall console for 5 seconds. The LED light on the wall console should stop flashing and the LED light on the receiver should start flashing.
Release the "Open" button on the wall console. The LED light on the receiver should stop flashing, indicating that the wall console has been successfully programmed to the receiver.
If the above steps do not work, you may need to reset the receiver and try the programming process again. To reset the receiver, unplug it from the power source and wait for 30 seconds before plugging it back in and repeating the programming process. If you are still having trouble, you may want to contact the manufacturer for further assistance.
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote Here is a copy of your manual www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
