Cell Phones Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased a new Nokia E63 phone. Whenever calls come, it rings but it don't vibrate. As Vibration is on. Please tell me what should I do...?
Anonymous
Level 2:
  • Expert 75 Answers
  • Posted on Jun 09, 2011
Anonymous
Expert
Level 2:
Answers
75
Questions
0
Helped
6721
Points
243
Possibly check to see if airplane mode is on. Also try turning the volume up all the way, I know some phones have an issue where turning the volume down all the way turns off vibrate. Hope this helps alittle
1helpful
I have nokia e63 which is only vibrate but no on
it has a water damage??? if yes, dessasembly your phone ad re-hot it with a hot station, if you don't have it use your iron... post result
tip
How to Fix iPhone Not Vibrating?
If you are in a meeting or attending a special event, you probably set your smartphone to silent mode to avoid any distractions from your phone. But what if there is an emergency? You will miss the calls and texts from your phone and then regret it later after realizing that it is a very important matter that needs to be discussed with you.
If you don't want to disturb your meeting or the people around you when your phone receives calls or texts, then choose to vibrate mode instead of silent mode - at least you will be notified if your phone receives any notifications. But what if you are using an iPhone and you learned that the vibrate mode is not working. What would be the reason behind it?
/uploads/images/fix-iphone-not-vibrating-undefined-undefined-0.jpg
Fix iPhone not vibrating
Now, if your iPhone is not vibrating when it receives calls, texts, notifications, or when you switch on the ring or silent mode, then you need to learn some of the solutions to fix this issue. Here are the 3 effective solutions that you need to know.
Solution 1: Check the iPhone Vibration on Sound and Haptics Settings
One of the basic things that you should learn about your iPhone is how to set the phone settings, especially the vibration mode. If your phone is not vibrating, go to your iPhone settings then navigate to the sounds & haptics option and check the vibration mode from ringtone to text tone - if off, turn it on. Then disable the focus mode that restricts the vibration of the app's notification.
Solution 2: Check the iPhone Vibration on Accessibility Settings
After enabling the vibration in the sound and haptic settings but still your iPhone is not vibrating, then go to the accessibility settings and check the vibration mode is turned on.
Solution 3: Fix iPhone not vibrating via iOS System Recovery
If the first two solutions didn't work on fixing the vibration issue of your iPhone, don't worry. With the iOS System Recovery, all iOS errors will be fixed including the vibration issue of your iPhone. This reliable tool can quickly solve any type of iOS error.
on Jul 14, 2022 • Miscellaneous
1helpful
No sound coming form the phone at all, it is only vibrating, i have changed the profile on it to outdoor and made sure the phone is not on vibrate in any way. You help would be much obliged. Jordan
Select the profile you want to use,then select 'customise' select 'ok' at the bottom of your screen, select volume on the new display page to verify your volume level, select back to previous page, then select 'alert type', now you can make selection of how you want your phone to alert you of an incomming call. i.e. Ring; Vibration Only;Vibration and Ring; or Vibration then Ring.
Sep 13, 2011 • Cell Phones
My nokia e63 doesn't have ringing tone when somebody's calling me,no message tone whenever i received txt messages.. i also cannot hear the other line. can somebody pls help me...
probably the buzzer of your phone is done.buzzer is like the speaker of your phone.drop by to any nokia center for checking or just bring it to a cellphone technician.good luck.
Samsung epic galaxy S running Android 2.2. Phone stopped vibrating. Why? Purchased on 4-1-2011.
problem is either with your ringer settings or from the ********.
Check your ring tone settings, see if vibration is enable/active.
If vibration is enabled and you still don't feel any vibration from the phone, then it means your phone's ******** has become defective. Below is an image of what the ******** looks like:
Also, factory reset the phone and see if that would solve the problem. If resetting doesn't solve the problem, then know for sure that the problem is with the ********. It might have loosed contact and shifted from it's normal position or it maybe defective.
Let me know if you would like to replace the ******** yourself or not.
Take care.
1helpful
2answers
Ibought my nokia e63 a week ago. Now there is no sound when it rings and no vibration i did go to the settings and set everything the way its supposed to be. I did not let it fall or anything. I put my...
u can try this
go to profiles then select the profile u want to activate then go to its customize menu and incoming call alert type and select it ringing
3helpful
2answers
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
7helpful
Vibration problem of nokia 6300 i want solutions
Does the vibration not work when a call comes or is it vibrating non stop? In either case you need to restart your phone and try calling to it to make sure it vibrates.
If it is not vibrating, then check phone ringing settings and make sure it is set to vibrate + ring.
2answers
My cell phone always vibrates
u edit ur profile and disable vibration first it wil automatically change ....
eg: u selecting meeting profile means u can edit that profile and turn off the vibration
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
