Hi,the jar file might be corrupted or your mobile will be protecting from something (virus etc) that jar file carries to protect your mobile, so the net breaks. Try installing any other jar file and see if the problem still persists. hope this helps, thanks!
Dear Friends, I've tried the code*#52828378# and changed the OTA test and finally succeeded to install my software, but the problem is that after launching i see this message: Java Error: No memory available....!!!! Could you help me?
I M HAVING SAMSUNG GT-C-3222(CHAT 322) PHONE AND M INDICATOR
DOWNLOADED IN MY PC FOR THE SAME IS SHOWING JAR FILE IS OVER MAX LIMIT
& ITS DISPLAYS JAVA ERROR EVERY TIME WHEN I AM INSTALLING &
REGISTERING THE APPLICATION
PLS REPLY URGENTLY PLS REVERT BACK ON MAIL. MAIL ID - [email protected]
Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500 to 4000 then save. You can now install as much higher than 500 kb but less than 4 mb.
hey dude i just had d same problem and got it solved 1st thing to do is delete 4.2 and download 5.1 fron net just google it 2nd thing before runing application bring down highliht to opera mini dn select more den connection dere u will hav a no. of profiles chose 1 of dm at a time and save now start d opera mini u will eithr connct or it will show some error if it show error dn exit it and try with anodr profile nd repeat again 1 of dm will work atleast did workd out for me i had vodafone nd vodafone live workd out for me all d best....!!
in order to install a java application u need two files one is JAD and other is JAR some phones require both and opening the jad file will install the program.. transfer both jad and jar file onto same folder and then install
