Quoted from:
Transfer iTunes to HTC Evo 4g Q: "I have some AAC Music I bought from iTunes but when I put some of them on my HTC Evo SD card it says this Music cannot be played. Is there any way around this? Or an app I can get?"
A: "Here is the thing, Apple's iTunes AAC (m4p) music and other protected WMA music with DRM protection can't freely transfer or playback on other devices, If you want to play iTunes AAC music on your HTC EVO 4G, you just need to use some
DRM Converter software to convert the iTunes music to HTC EVO 4G compatible format."
This Text will show you how to
remove DRM from iTunes music, Convert DRMed iTunes AAC(M4P) M4A WMA to MP3 and transfer to HTC EVO 4g, HTC Desire, HTC Incredible Step1.
Free download Daniusoft DRM Converter, install and luanch it, the default settings work well with your PC, you don't need to make anymore configeration.
Step2. When come to the main interface, click "Add" to import DRM license protected music video files from iTunes or common files you want to convert.(you can right click on a song in iTunes, select "Get Info", and it will tell you where on your computer that file is located)
Step3. Choose the target output format you need.( HTC Touch Evo 4g/Desire/Incredible compatible audio fomats: MP3, WMA, AAC ,etc and Video fomats: MP4)
If you want to customize output setting, just Click "Settings", there will be a pop up window displaying the output settings parameter, such as Formats, resolution, frame rate, bit rate etc.
Step4. Convert iTunes to HTC Evo 4g or HTC Desire/Incredible
After finishing all the necessary steps, you can click "Start" to start converting your file. When the conversion progress reaches 100%, the DRM Copyright protection on iTunes is removed and conversion is easily done!
Step 5. Transfer converted iTunes Music to HTC Evo 4g, HTC Desire/Incredible
After you get the output music files, you can connect your HTC EVO 4G or HTC Desire/Incredible to your computer via USB, select Disk Drive when your phone asks. Then go to My Computer and click on your phone. it should appear as an external hard drive. There should already be a music folder with the preloaded songs there. You can now just copy the music of your iTunes into that folder and your HTC EVO 4G or HTC Desire/Incredible will now have all your music in the Music app directly.
remove drm from wmv '
iplayer ripper '
remove drm from itunes 10 '
itunes to droid '
Transfer itunes music to htc evo 4g '
wmv to ipod touch 4g '
drm removal '
convert m4p to mp3 '
amazon video on demand ipad '
remove drm from itunes '
remove drm from nokia music store '
m4v to droid '
iTunes to galaxy s tab
