Only the fan is running Thanks. Douglas Bisson..
Mr Bisson, there are several things that can casue the problem you have. All of which a usually solved very easily.
1. Dirty or clogged air intake filter. Remove and clean the filter per the manufacturer's instructions. Clean the filter once every two weeks, as part of routine maintenance.
2. The humidity extraction level is set to HIGH. Lower the setting to 35% or lower.
3. Obstructed air flow. Maintain a minimum of 12" clear air space on all sides of the unit, while in operation.
Any or all of the above can cause the problem and are easily solved. I hope this helps to troubleshoot the unit and solve the problem..
