Question about Galaxy Radios DX-959 40-Channels Base CB Radio
Just purchased a new galaxy dx959. Coax and k40 10k watt antenna. Installed it in my peterbilt 379. I have a lot of background noise. I tried unhooking the coax from back of radio and the noise goes away. So I figure its not coming through the power cord. What can I do about this? Also can I turn up my vr 14 and vr 16 and get more audio?
Posted by thecaptai127 on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
You probably have the 959 that has a MOSFET final. It is not recommended that you try to get more power/mod by just turning pots. This can shorten the life of the MOSFET drastically. I normally set the power output to 7 watts and the mod to 100%. This give around 30 watts peak on AM and around 25-30 watts sideband. You need proper test equipment to align the radio.
As far as background noise, this type of radio does have more that others. Make sure the Noise blanker and ANL are turned on. If you are getting noise from equipment in the vehicle, you should take your truck to a good CB shop. They can find out what is causing the noise and fix it.
....Don at NTCB, Inc.
Posted on Jun 29, 2011
Ive got a galaxy 99 i put new coax 18ft and a new k40 antennae 10 meter type i cannot get the swr to come down.i have tried grounding everything but no change.i even bought a new meter
How low do you want it . anything below 2 is fine and even 2.5 isn't going to hurt. its when you get higher than that then you should worry . Relocate your antenna on your vehicle. When you bought the new antenna and coax did you buy a new mount also ? You may have to shorten the antenna or lenghten it also to get a good match .
Mar 04, 2018 | Galaxy Radio Communications
I am getting motor noise I put my hot wire to battery and ground to frame still have the noise I still have factory coax in 2006 t800 kw do you think neww coax will help the noise
the noise you hear could be from the ignition .It could be from the firing of the fuel injectors , from the fuel pump to just plain old ground noise .Check your ground to the antenna ,make sure it is grounded good .If the noise is still there then you will need to get a noise filter for your radio to be installed between the radio and the antenna. The other thing you can do is buy some good coax and run it instead of the junk they have installed in the mirror brackets. Remember the older the truck the more likely the coax is to be worn in places you can't see. The other thing is you really don't know if you are connected with that coax.The connector could be not connected on either end even though your radio connector is connected.
May 30, 2015 | Stryker SR497-HPC 10 Meter Radio
What is the best way to run cb coax in a 2006 peterbilt 379
don't they come with coax and antennas already installed? If you can run the coax out the window to the mirror bracket then up and over the visorsthat would be good.the only thing is if it has a fiberglass door,no ground plane. you will have to then ground the antennas to the chassis and maybe even use a grounding strap.
May 24, 2014 | Cobra 29 WX NW ST 40-Channels Base CB...
How to Hook up My galaxy 250 watt Linear Amplifier to My galaxy dx959
you will need a jumper cable to go from the box to the radio then the antenna plugs into the box at the antenna connection point.Now for DC power you will need at least some 12 gauge wire with a fuse connected to the pos and the neg. Then you connect it to the fuse box and a ground . I personally would not use one ,if my radio cannot out do yours then so what.If you can't hear my radio within 12 miles of me then I will talk to you when you get closer.You want to hook one up thats your option but I don't even want one.
May 27, 2012 | Galaxy Radios 959 40 Channel Am/ssb Radio
We are trying a radio check for a mirage 66 but the static only goes away when we turn the squelch all the way down and we can't hear anyone
Sounds like you have a lot of interference. Could be something in the vehicle causing all the noise. Try it with the engine off. Also make sure the antenna system is correct. for example, coax good. antenna grounded. SWR low. etc.
Oct 02, 2010 | Galaxy Radios DX-66V Base CB Radio
I have a Galaxy 73 V when I install it in a Nissan Truck, I get lots of Noise, I have attached a Commercial Noise Filter in Line but the Radio Audio becomes muted. I can install a Galaxy DX 959, same...
Where does the noise filter go? if it goes inline with the antenna, don't use it!!! It's bad for a cb radio.
The problem is that the V73 has a very sensitive receive. It is picking up noise in the car. Most likely the smog pump, or fuel pump.
Here are a few things you can try.
First, lets make sure where the noise is getting into the radio. It will either be getting in via the power wire, or the antenna.
To find out, here is what you do.
  1. Turn the car on, and the radio on.
  2. unscrew the antenna from the back of the radio. Make sure you do not key the radio without the antenna hooked up. It will hurt the transmit section.
If when you take the antenna wire off the back of the radio, the noise goes away, then the noise is getting in via the antenna system. Solutions for this could be any of the following.
  • Bad coax or connectors. Replace the coax with new coax.
  • Antenna not ground, or poorly grounded. If its a mag mount antenna, make sure the membrane on the bottom is in tact and there is nothing in between it and the metal of the car. this is how the antenna is grounded. If its a rigid mount to the body of the car, make sure it is free of rust or paint where it is mounted.
To find out if the noise is getting in from the coax, or antenna.
  1. Hook the coax back up to the radio. The noise will be back.
  2. Disconnect the coax from the antenna if you can.
If the noise goes away, it is the antenna. Try a new antenna. If the noise doesn't go away, its most likely bad coax.
Now if when you disconnect the antenna wire, the noise is still there, then the noise is getting in through the power wire.
Here are some things you can do to get rid of the noise.
  • Connect power wire direct to the battery.
  • Twist the power wire.
  • Put a not in the power wire right at the plug.
  • Use power line noise filter. It is a ground loop filter.
Some vehicles are noisy. You can't get away from it. Even with all of the solutions you may still have some noise. It's like that in my f150 pickup. I can't completely get rid of the noise, but most of it. In my blazer, I can hear the ignition noise if I do not use the ANL. In my friends dodge, he has no noise at all. Even without the ANL on. It's amazing.
Sep 04, 2010 | Galaxy Radios DX-73V 40-Channels Base CB...
Galaxy DX959
The 959 is not one radio you can get alot of power out of possibly 25 watts if it is tuned properly
Mar 16, 2008 | Radio Communications
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Galaxy Radios DX-959 40-Channels Base CB Radio Logo
220 people viewed this question
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
Tom Chichester
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
