Question about LeapFrog Leapster 2 Learning System
I turn on my daughter's Leapster 2. I sign in. I click "Cartridge Game". The screen goes black & then It goes back to the "Leapster 2" screen, followed by the "if you see your name"...sign in page. I tried changing the batteries, tried using a different log-in name, tried a different cartridge. Nothing works. Please help!
Posted by jjd613 on
sicomel
    New Friend:
  • 18 Answers
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog Connect, you can also get more downloadable games for your Leapster 2. You can get it here:
leapster-2.blogspot.com
Posted on Jun 29, 2011
The pen on my sons leapfrog leapster won't work
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge.
Sep 05, 2012 | LeapFrog Leapster 2 Learning System
Tip
How to Sync Stylus with LeapFrog Leapster 2 Learning System
If you need to sync the device to the stylus just follow the steps below.<br /><br />1. Turn your <span>Leapster</span> 2 off, and remove the game cartridge<br /><br />2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.<br /><br />3. With your finger still firmly on the 'hint' button, turn the <span>Leapster</span> 2 back on. Keep your finger on the 'hint' button.<br /><br />4. The screen should be displaying the calibration screen. You can release the 'hint' button now.<br />5. Press the 'A' button on the right to enter the calibration screen.<br /><br />6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your <span>Leapster</span> 2 throws at you.<br /><br />7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.<br /><br />8. Your stylus and touch screen should now be working, enabling you to sign in as usual.<br /><br />9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.<br /><br /><b>Thanks for <span>using</span> <span>Fixya</span></b>
on Mar 09, 2011 | Toys
I can't calibrate the leapster.I can't get pass enter a name
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
1. Turn your Leapster 2 off, and remove the game cartridge
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
If you have questions please let me know.Thanks for using Fixya
Aug 03, 2011 | LeapFrog Leapster 2 Learning System
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Jan 30, 2010 | LeapFrog Leapster Learning Game System
The touch screen does not work on leapster 2
Turn off the Leapster2 and remove cartridge (if there is one).
Push and hold down the hint button (the one with the question mark) while the game is off.
Turn the Leapster on while still holding down the hint button until you see the calibration screen.
Turn the Leapster off and then back on again without a cartridge. Login as usual.
If this does not work, then call customer service, depending on how old it is. I've had ours for over a year, and this still works each time.
Dec 30, 2009 | LeapFrog Leapster 2 Learning System
My daughter has a Leapster 2 (pink) hand held game. We can not get it to sign into her name, so she can not play games. Can you help?
Remove the game cartridge, while holding down the button with the "?" turn the unit on. Then the screen should tell you to press the "A" to calibrate the stylus. Finish the calibration by touching the crosshair when it appears. After I did this everything was fine. Good luck ....thaks to Nicksdad who posted this response to a previous post. Worked for me...try it.
May 16, 2009 | LeapFrog Leapster 2 Learning System
Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Apr 06, 2009 | LeapFrog Leapster 2 Learning System
Leapfrog Leapster
I've tried the Home and A button several places... and it seems to work for others but not me :( I was about to give up then I found another way to reset the screen - Hope it works for you!
1. Unit must be OFF and NO cartridge
2. Hold down the HINT (?) button while turning the unit on
3. When Leapster menu screen appears, press the A button
4. Touch each of the cross hairs that appear with the stylus
5. Restart unit
Dec 01, 2008 | LeapFrog LeapSter L-Max Console
LeapFrog Leapster 2 Learning System Logo
1,266 people viewed this question
Top LeapFrog Toys Experts
Marvin
Marvin
Lawrence Oravetz
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
