Question about Canon C2058 Color Copier
When the printer prints a page theres yellow on it. why does it do that?
Posted by deedee5192 on
Paul Pettit
  • Canon Expert
  • 270 Answers
Most likely the Yellow drum is failing. Check to see when it was last changed. They are expected to last approximately 50,000 prints or one year.
Posted on Jun 15, 2011
C546dtn printing too much yellow
Check the yellow drum unit carefully, could be a full or clogged waste toner collection unit.
Nov 14, 2014 | Lexmark C546DTN Color Laser Printer
Yellow not printing in Canon iP6600D printer
in the print out alone you can already know what print head is no working properly like missing color. if cleaning is not solving the issue this purging the print head. just read the user manual for the instruction
Apr 29, 2013 | Canon Pixma iP6600D InkJet Photo Printer
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
Yellow lines appear in printed outputs on my Epson 1280. Printer was inactive for about 5 months. ....have cleaned and soaked print head several times. Lines are less intense, but still there. Thanks...
There are two possible causes: 1. The ink dries on the plate around the head output (sprayer), 2. Thin coatings of yellow head broken. The first possibility can be tested by printing blank pages (or just containsthe line - full pages). If after about 50 pages to print, yellow lines had been lost, then the printer is ready for use again. But if not, then thesecond possibility happens. At the output of the head there is a thincoating. If until the coating is breached, then the ink will drip continues,although there is no voltage or current that supplies the headmicropiezzo.
Jul 12, 2011 | Epson Stylus Photo 1280 InkJet Printer
How do you go about cleaning printer head
there is a cleaning utility "printhead clean" and printhead deep clean" under "maintenance" in the "printer properties". Try that first. If that doesn't help and there is definitely ink in the cartridge(s), you can remove the cartridges and soak the printheads in 5mm of hot water for 1/2 hour or so. DRY WELL then install back in printer and run "printhead deep clean".
Another way is to isolate the colour that doesn't print properly and print few pages in that colour (eg if yellow is not printing right...set out a full page of yellow background and print on high quality setting until yellow starts to print ok). This wastes less ink than the cleaning utility.
good luck with it
LC1000
www.inkbank.com.au
Dec 02, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
My copier is printing yellow throughout the page when it shouldnt
all colour empty in your cartridge. only yellow colour is in. so all printing is yellow. black colour cartridge too empty.
Feb 25, 2010 | HP Officejet Pro L7650 Printer
C88 / T060 cartridge refilling problem
sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
HP DeskJet 970Cse won't print yellow
Here is a link to hp's web site. They will troubleshoot your issue. This link is linked to a page talking about HP Inkjet Cartridges and Media - Missing Color, Wrong Color, or Streaks in the Printout. There are several links in this site to go off of and troubleshoot further. Hope this is helpful:) http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00224&lc=en&cc=us&dlc=en&product=60097&rule=34749&lang=en Jason
Sep 04, 2007 | HP DeskJet 970cse InkJet Printer
Canon C2058 Color Copier Logo
35 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
