Question about Samsung DLP HL-P5663W 56" TV
TINY WHITE SPOTS ARE APPEARING ON THE SCREEN OF MY SAMSUNG DLP TV, IS THERE ANYWAY TO FIX THIS PROBLEM?
Dream
  • Samsung Master
  • 6,271 Answers
How to Unlock Samsung Phone with a Broken Screen
Android Lock Screen Removal & Data Recovery is your best choice to remove locked screen on Samsung with broken screen.With its help,it's no longer be a problem to unlock Samsung broken screen without password.It can help Samsung users disable the password and pattern locked issues on Samsung device with just few steps.Applicable Samsung device including Samsung Galaxy S10/S9/S8/S7/S6/S5/S4,Note 9/8/7/6/5/4/3,etc,.
LEARN MORE
Broken Android Data Extraction
Recover Samsung Data when USB Debugging is not Working
How to SIM Unlock Your Samsung Phone or Tablet
How to Fix Wet Samsung Phone
How to Fix Samsung Stuck in Boot Loop
Posted on Sep 10, 2019
dick davis
  • Samsung Master
  • 610 Answers
The DLP chip is failing and will have to be replaced, very expensive. You can call samsung at 1-800-samsung to find the closest service center.
Posted on Jun 08, 2011
Many, numerous, and increasing white spots appearing on the screen of DLP Samsung tv.
The White spots you see is the LED's thats not working you need to take it in for repairs as soon as possible otherwise youll have a blank tv soon.
May 10, 2011 | Televison & Video
I have a 67" DLP TV and last night 2 white spots
That usually indicates that the optical block is going bad. That repair is usually 900-1100 dollar fix.
Mar 30, 2011 | Samsung HL-67A510 67" DLP HDTV
Spotty tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Jul 27, 2010 | Samsung DLP HL-P5663W 56" TV
Small white spots appearing on T.V. screen.
The DLP chip is failing and will have to be replaced. Samsung is covering the cost of repair for this problem on SOME models. You can call 1-800-samsung to find out if your unit is covered or to find the nearest service center.
Jun 30, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung hl-t4675s white spots on screen started now screen is almost black lost pixel what is cause
My Samsung LCD has white spots on the screen. The tiny spots seem to be increasing in numbers. I am outside my warranty. Is this going to cost a lot. It is a 43in screen.
Jul 16, 2009 | Samsung DLP HL-P5663W 56" TV
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
408 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
