If you need to replace the bulb then this site might help :http://www.steves-digicams.com/knowledge-center/how-tos/troubleshooting-repair/how-to-replace-your-digital-camera-flash-bulb.html
Otherwise, if the camera is still under warranty then you can send it back to be fixed.
Testimonial: "helpful"
SOURCE: sony cybershot camera DSC-P100 Digital
I don't have a repair manual but I can fix your LCD if you got one. If you don't have LCD, I got one to replace. Let me know what you would like to do. Thanks.
SOURCE: sony dsc p100
Not sure what you mean? You have 16 single shots one after another Now what do you want to do? Turn the camera back to single shot? Read the Manual -Full manual in PDF format on disk Do something with the shots themselves? Use image editor in computer Do none of these? Try another way of putting the question
SOURCE: flash not working on Sony Cyber-shot dsc-p100
With the flash activated put the camera to you ear. assuming you have normal hearing when the flash capacitor is charging you should hear it.
If you cannot then assume the flash unit has failed.
Replacing it is possibly a no no
The economic cost make a new camera a better bet
Check out Sony to be sure
SOURCE: cannot copy my photos from
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Thank you
