Minolta DiALTA DI2510F All-In-One Laser Printer Logo
Anonymous Posted on Jun 08, 2011
Problem on Minolta DIALTA DI 251? my copiers haVE detected problemS, one says code M4 What are the problems?
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 21, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910714
Points
11959
Touch the Utility, Meter counter, Stop00 stop 01, now in service mode now stop 9 select copy kit counter then select mode 1
M-4 is set up to monitor what ever the tech wants it to be
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1 Related Answer
Anonymous
  • 4323 Answers
  • Posted on Jan 01, 2011
SOURCE: Problem on Minolta DIALTA DI
Hi
Error code C070 or C0070 is related to toner not seated properly. Power off the machine and gentlly take out the toner bottle. Turn on the machine without the toner bottle, let the machine go through its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
C0500 means Heating Roller warm-up failure. Open and close the right side door. There's a switch hidden under the frontcover activated by the side door. Sometimes the grey plastic arm attached to the sidedoor is not actuating that switch properly.
To reset the error Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter "3" from the 10-Key Pad when dot appears at the center on the left side of the screen while the start-up screen is being displayed. (Enter code 0000) You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or thermistor. Hope this helps... Please post back if you need more information.
Daniel
Re DiAlta di 251
What about the Di251?
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Minolta di 251 error code c133a
Electrical disconnect Draws #2 draw #3 draw #4 and Draw #5 all connections for each of those draws is in the rear middle cover. Also remove the job tray that the device where the paper comes out for faxes print etc. leave only draw one connected power off the machine turn back on after ten seconds. if the code is gone have a bad draw (s) if it comes back replace the main board if you can find one. The Di251 is legacy machine Minolta is now Konicaminolta. If the code did not come back your going to start connecting each draw back one at a time. Fig out which one(s) is causing the problem
2answers
MY MACHINE DI 181 SHOWS SERVICE CALL M4 AND DOES NOT COPY
This M4 code means that your drum life is over. You have run 80,000 copies or more on the drum. If you have a local service company available then I would just have them come out and clean the machine and reset the counter. This is especially true if your copies were still fine prior to the machine shutting down. Service mode entry and navigation is rather complicated on this machine so I do not feel comfortable trying to walk you thru the reset process.
Good Luck and Thank You for using Fixya.
19helpful
3answers
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
5helpful
2answers
Minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
4helpful
3answers
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
6helpful
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Minolta di 251 srror code coo7o
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
