Dryers Logo
Posted on Jun 11, 2017
I have a Hunter Ceiling fan/light combo w/ remote; part # 85094-01 that has been working great for about 3 years. I have taken it down 3 times in the 3 years and moved to different locations. No problems at all until my recent move. I installed it just like every other time, but the remote control will not control the ceiling fan or light. I replaced the batteries and still no help. I made sure that the jumpers are the same in the receiver and remote. Please help!?
5 Related Answers
Coldcut
Karl Whisenand
  • 1554 Answers
  • Posted on Mar 31, 2008
SOURCE: wiring a ceiling fan with a remote sensor
since you have a remote, you don't need that extra wiring for the light/fan. just wire nut it off.
the switch at wall has 2 switches but only one will work now.
muttandjeff
Allen Neal
  • 359 Answers
  • Posted on Nov 27, 2008
SOURCE: wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Anonymous
  • 137 Answers
  • Posted on Mar 02, 2009
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Anonymous
  • 5 Answers
  • Posted on Aug 13, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
if the battery's are good then you broke it and you have to order a new one which you can do by calling the place that you got the fan from tell them what kind of fan you have and let them know that you nead a new remote and they will be able to help you do that.
Anonymous
  • 3 Answers
  • Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
How to bypass hunter 85112-04 receiver?
Just replace it
Works as a direct replacement for Hunter part # 85112-04
https://www.amazon.com > customer-reviews
I have a Hunter fan that is about 10 years old. The remote receiver stopped working. Unfortunately, Hunter has discontinued the part, 85112-04. This item works ...
HUNTER Replacement 85112-04 (8511204000) Receiver ...
https://www.ebay.com > ... > Ceiling Fans
Original Hunter Receiver 85112-04 (8511204000) is no longer available and is replaced by our FAN2R KIT. Works for: 3 Fan speeds Low, Medium, High, Fan ... US$59.99 · ‎In stock
Hunter Fan Receiver 85112-04 for sale online ' eBay
https://www.ebay.com > ... > Lighting Parts
Find many great new & used options and get the best deals for Hunter Fan Receiver 85112-04 at the best online prices at eBay! Free shipping for many ... Rating: 4.8 · ‎4 reviews
Accessory Receiver - 8506802000 ' Hunter Fan
https://www.hunterfan.com > products > ceiling-fan-par...
Delivery between Monday, May 24 and Tuesday, May 25. Order within 23 hrs and 28 min. This item is out of stock. We'll email you when it's available! Product ... US$55.00 · ‎In stock
I have a Hunter 94974 fan receiver 85112-04. All remote functions work except it won't switch to the lowest fan speed. The red light goes on when I hit the button. Is ... US$55.00 · ‎In stock
2helpful
2answers
I can't turn off my ceiling fan. Remote batteries are new. Fan not connected to a switch
need to disconnect the power source to fan then test the transponder / relay in fan possible faulty and will probably need to be replaced
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
1helpful
4helpful
2answers
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
4helpful
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
1helpful
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
3answers
Hunter ceiling fan
Have you contacted Hunter? Have you turned off the wireless internet to see if fans work? You may have to try another internet brand or try moving to another part of the house.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Hunter Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
