You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
If you are using Media Player, open media player, click on View, then Enhancements, choose Play Speed Settings, move to the bottom left of the screen and select Normal, it will be between Slow and Fast. Let me know if this helps
I work at the History Channel and have a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking
would bring in the audio, but sometimes the video would get fuzzy. Get
the picture right and the audio goes out. Switch to Linear (mono on
some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
The idler wheel (that only drives the tape in play or scan modes) is
slipping too much (very common problem). Try verify this by
putting the tape in play then immediately press the fast fwd or rewind
buttons to scan the tape. On older machines, the idlers used
rubber friction tires - on newer ones, a clutch. Either replace
the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
