Question about Watches
TRying to set the analog time on my Elgin World Time Flight Chronograph model # fg010-007
Posted by ayalazar on
Carlos Colon
    New Friend:
TRying to set the analog - aa0e146e-a536-430b-b421-5974b40281d7.jpg here you have the manual
Posted on May 26, 2014
raj somaiya
  • Watches Master
  • 5,370 Answers
Click this link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/06/how-to-set-analog-time-on-elgin-world.html ----------- This should help.Thanks.Helpmech.
Posted on Jun 07, 2011
How can I set?
Shirley, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 17, 2016 | Watches
Setting chimes and time for elgin e77
I thought I had some instructions on that Elgin clock, but it was for a mechanical wind up unit. There were many different models of these programmable clocks manufactured and the instructions differed. And they are just not readily available. I received a sports watch in a trade (with no instructions)and after 3 months I am still trying to determine how to program it!
It might be that the "H" stands for hours and the "S" for set. So how do we set the minutes? I will pose this question to my Internet Clocksmiths Group and see if anyone knows. If I do receive some instructions, I will get back with you.
Buy Performance Parts.
Jun 04, 2012 | Elgin Watches
Need a user manual for the time magazine free chronograph watch
I have NO ideal what kind of watch it is so I am giving general chronograph instructions. You will have to use as it applies to the watch you were given.
These instructions are provided for users who are not familiar with using a mechanical/analog chronograph. The instructions may be applied to any chronograph that has a seconds counter, 30 minute counter, and hour counter.
Please refer to the instructions of the appropriate model to determine the location of each counter on the dial. Note: some of the features described here may not be available on your particular model. Again, refer to the specifications to see if they apply to your model.
Using the chronographe functions:
How to read the chronographe:
For a chronographe that has a center seconds register, a 30 minute register and an hour register. Example 1: If the hour register is between the 1 and 2, but closer to the 1, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 20 minutes and 35 seconds. Example 2: If the hour register is between the 1 and 2, but closer to the 2, and the minute register is at 20, and the seconds register is at 35, then the elapsed time is 1 hour 50 minutes and 35 seconds.
How to read the tachymetre:
If you are driving and want to determine the speed of the car using your tachymetre, start your chronograph when you pass a mile marker, stop your chronographe when you pass the next mile marker. Look at the center seconds hand and read the number on the Tachymetre scale, this number will indicate the miles per hour that the vehicle is travelling.
How to read the pulsometer:
Some watches have a pulsometer instead of a tachymetre. Use it as follows: Start the chronographe and begin counting the pulse. When you have counted 30 beats, stop the chronographe. The number on the pulsometer scale will indicate the pulse rate per minute.
How to read the telemeter:
Some watches have a telemeter instead of a tachymetre or pulsometer. Here is an example of one use for a telemeter: Start the chronographe when you see lighting. Stop the chronographe when you hear the thunder. Read the center seconds hand on the Telemetric scale and the number will indicate the distance separating the observer from the place where the lighting struck. This can give you a good indication of how far off a storm might be.
The many uses of a chronographe:
A chronograph has many practical uses, from timing a plane flight, a car ride, or simply being curious. There are also some uses for the chronographe that may not be so obvious. For example, you can use the chronographe on your watch as a dual timezone indicator. This is done as follows: If it is currently 6 A.M. in your home location and it is 12 noon in London, start your chronograph at exactly 6 o'clock. The number of hours displayed on your chronographe hour register will then show you the current time in London. Of course, these are just some uses of a chronographe. There are hundreds of uses for chronographes.
Instructions: Astronic Chronograph Chronograph Chronometer Power Reserve Chronometer Astronic Chronometer World Time Chronometer Retro Alarm General Chronograph Common Q & A's
Aug 12, 2010 | Watches
How to set time?? please advise. [email protected] or 913-402-0425 thanks
These generic skyhawk instructions should work with the Blue Angel. Great watch!
http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Sep 18, 2009 | Citizen EcoDrive Blue Angels Skyhawk...
Need instruction manuel for elgin fg010-007 sports watch
The movement in this Elgin is made by Citizen. After you change the battery, you need to reset the hands so that the watch functions properly. Select chronograph function with lower-right button. Then pull-out the same button. Push the upper left button to select the UTC, hour, and minute hands. Then use lower-left and upper-right buttons to make sure everything is aligned to 12:00 position. After setting the hands to 12:00, push in lower right button. Now you can set the time by selecting the SET using the lower right button. Pull out the same button and choose your time zone to set.
Feb 28, 2009 | Elgin Watches
10 year old alarm chronograph
good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
Sep 01, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Versace flc99d001s099
good after noon,to set the time and is depend on the model of your watch,if your watch is analog use the crown to set the time and date just pull the crown slowly and wind it,but if your watch is digital use the button to set the time,thank you !....
Aug 29, 2008 | Versace Gianni Atelier Chronograph
Watches Logo
1,076 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
