Question about Stanley Utility Knife
HOW TO OPEN THE 10-777 UTILITY KNIFE - Stanley Utility Knife
efs_perpends
    President:
  • 1,997 Answers
This is the closest thing I can find. Click here.
Otherwise, write Stanley support and they'll answer you here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 07, 2011
How do I replace a blade in a tajima GRI H utility knife
A good utility knife can change the way you work, while a bad one can make you project more difficult. A utility knife can perform a wide range of activities indeed. You can use it as a box cutter, a pocket knife, even as a camping knife. To be precise, the utility of a utility knife is far more than most people expect. That is why, everybody should have the best utility knife as a companion to their daily Do-It-Yourself activities.
May 30, 2018 | Cutter Tools
How do the springs go in a cobolt utility knife
the utility of a utility knife is far more than most people expect. That is why, everybody should have the best utility knife as a companion to their daily Do-It-Yourself activities. More details BEST UTILITY KNIFE TO BUY FOR DAILY USES
May 21, 2018 | Cutter Tools
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Jun 26, 2011 | Stanley Utility Knife
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Oct 29, 2010 | Stanley Fatmax Xtreme Retractable Utility...
How do I put the first blade in the new knife?
open the blade all the way and turn the knob to loosen, then scissor the two halves to open
Oct 22, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Change blades I just need a picture /instruction for blade change
The gold looking circle on the side of the utility knife. Just unscrew that and it will pop open then you can change the blade. I looked everywhere and am unable to find the instruction or picture. I own one and that is why I am answering this for you. Please rate
May 31, 2010 | Stanley Fatmax Xtreme Retractable Utility...
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
I cannot open the front of the utility knife to replace the blade on model 10-788. Can you help me.. I can open the storage area but not the blade area to replace the blade.
I was able to find the answer on another site. It is really simple when someone tells it to you. You push the blade all the way out then you can push the yellow button and it comes out.
Sep 06, 2009 | Stanley Utility Knife
Stanley  Utility Knife  Logo
951 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
