C0500 is a warm-up error on those little machines. Try holding the stop button while switching on, that should reset the code. It sometimes happen if it's kinda cold, or when the power dips. If the code comes back, you'll have to replace the fuser unit.
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
How to clear a fuser error code (C0500, C0501, C0510, C0511, C0520, C0521).Solution
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .3. The code should clear and a message to close the front door should appear.
Fuser malfunction.
Power off/on while pressing Stop.
Not recommended without having been checked by a service technician since it could result in a fire.
