Addressing Power-up/Start-up Issues: E. Some models require you press down on the Start button until the unit powers up. F. Some models require you press down on the Select button until the unit powers up. G. Some models require you press the Select button first before pressing the Start button. In the end, were you able to confirm that your breadmaker is receiving power? No. Sorry to hear that. Have the breadmaker serviced by a small appliance repair shop or simply discard it. Yes. Fantastic! Now reboot the breadmaker's electronics by pressing down on the Stop button until you receive a visible and/or audible confirmation, usually within 1 to 5 seconds. Note: Some models require you press down on the Start button instead. And yet a few others require you press down on the Select button instead. Often the + and - Delay Timer buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect this handy feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. Note: All breadmakers use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn during the kneading cycles, your timing belt is probably broken. You'll need to disassemble the breadmaker to visually confirm. The belt and pulley assemblies are located at the bottom of your breadmaker.
Did this answer help? Hope so. Please rate it as soon as you can. Thank you. r53w6t
