Question about Sony STR-DE845 Receiver
Sony receiver model str-de845 need owners manuel
    Brigadier General:
  • 8,546 Answers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
Posted on Jun 07, 2011
Bought a used sony str de845 with rm adu007, need program manual for rm.
If the remote is functionally the same as the original RM-LP204
Apr 11, 2011 | Sony STR-DE845 Receiver
I have Sony STR DE845 receiver and comcast red button dvr remote. Anyone know the code to have the comcast remote control the sony?
If you consult the card that came with the remote, you will find several codes for "Sony". You will need to experiment with each code until you find one that will power the receiver on and off. Then you will have control of the receiver. If you don't have the card, then go to the web site and download a copy in PDF format from there. I have a lot of Sony stuff, and I have found that the codes varry according to the year the equipment was made and its function.
Aug 31, 2010 | Sony STR-DE845 Receiver
Sony str-de845 powers on, relay clicks sound works for a few minutes then relay clicks again and sound stops. display stays on.
Hi there, can anyone help me? i cant seem to get my aiwa-d58 to get out of eco mode. no power, red light is on and every time i press the power button; the eco light clicks off and i no power supply to the whole unit. please help!
Jan 22, 2010 | Sony STR-DE845 Receiver
I have a Sony STR-DE845 receiver. The rear
Something is heating up to a point that it fails in the rear amplifier section. take it to a tech.
Jan 01, 2010 | Sony STR-DE845 Receiver
Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Sep 15, 2009 | Sony STR-DE845 Receiver
Sony atr-de845
Open it up, check by where the power cord comes in there should be a fuse. Check to see if it is blown. If so it is an easy fix. Replace the fuse with same type. If not the capacitors are gone and that is expensive to replace.
Dec 09, 2008 | Sony STR-DE845 Receiver
Sony str-de635
It may need soldering of the display, could also be a bad resistor or transistor in the power supply.
Dec 08, 2008 | Sony STR-DE845 Receiver
Sony STR-DE845 Receiver Logo
170 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
