TDK DA-5900 2-Disc CD Recorder Logo
A
Anonymous Posted on Jun 07, 2011
I need to know the exact type of blank CD's to use in a TDK DA 5900 4X DIGITAL AUDIO CD RECORDER. I haven't used my machine for a couple of years and I have forgotten what type of blank CD to use. Can you help me?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jun 07, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767747
Points
24828
They say MUSIC or AUDIO on them. It's in the manual.
How do record a cd when i hit the record button or bun button it say no audio
It means the disc is not for recording Digital Audio. It would say so right on it. You can't use data CD-R's for recording. The manual explains it.
I need the manual for TDK DA -5900 4x Digitakl audio CD receiver
Asking the question a thousand times won't get a faster answer but a Google search will.
You'll have to register for free to get it here.
http://www.hifiengine.com/manuals/tdk/da-5900.shtml
How to connect DA-328?.Do I need special wires or terminals?.Don't have the operation manual!!.Thanks.
I can't help you with the manual but the rear panel is fairly simple and versatile...
http://gear.ign.com/dor/objects/481812/tdk-da-3826/images/tdk_da3826_io_scheme_big.html
Like any other recording device it has IN's and OUTs, but in this case there are two distinct units in the case - a Player and a Recorder.
You have analog in's and outs that accept standard Line Level RCA patch cords.
Coaxial Digital connectors carry standard digital audio in or out; ditto the Optical connectors.
I imagine that, being a dual deck, it has internal digital routing for copying from the Player to the Recorder.
I also imagine it requires CD-R AUDIO blank media for making recordings; not computer CDR's.
Recording with tdk da-3826
Data cds will not work with this recorder.
You must use music or digital audio cd's when recording!
3answers
No audio
Select the analogue source input.
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
2answers
NO RECORD
This message usually indicates that a non-audio disc is in the record tray. Please use only blank music CD-R or CD-RW media. Refer to page 12 of the owners manual for more information regarding acceptable media type for the DA-3826. Also, the laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a CD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Top TDK Audio Players & Recorders Experts
August Brown
August Brown
Trond Baarli Olsen
Trond Baarli Olsen
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
