Trilogy ALARM LOCK PL3000 Series  T3 Prox Cards Only Keyless Lock Logo
Question about Trilogy ALARM LOCK PL3000 Series T3 Prox Cards Only Keyless Lock
I recetnly had a problem with my hard drive and had to replace. We reinstalled DL and copied old directory on new directory. Now when i try to access DL I recieve an error message Error 3204 Data Base already exist, occured in Create Acct Log File. I enter OK and another error message appears: Could not read index file Check Working Directoryu Path Using Application Directory. I eventually gain access after closing error message several times and then access DL. Any way I can correct these problems?
Posted by towers2100 on
Anonymous
  • 963 Answers
I can't help you directly, but I can direct you to the manufacturer's website, where you can find further Contact information for technical assistance, and under Tech Support, a link to the tech library page where you can research instruction manuals and download software, etc.
http://www.alarmlock.com/
Go to that page, then check under "Tech Support" or "Contact".
Posted on Jun 12, 2011
I had Print Shop 10 installed on Vista.After a hard drive replacement, I cannot reinstall it. I need to retrieve my files.The clean install I used before is not working. Any suggestions?
If you have the old hard drive , hook it up to your computer as a secondary unit and boot up with your new replacement. Then using windows explorer access the secondary drive, retrieve the files you want and either transfer them to an external usb stick or create a directory on your new drive and transfer them there until you can get a fresh copy of your program installed on new drive.
tip
Crashed Windows : No Problem
MS Windows, irrespective if its version, is famous for crashing. We have all witnessed the infamous "blue screen of death" once in a while. And when it does crash, we have to reinstall the operating system. Thus loosing the precious data that we have collected over the years. A long but avoidable sob story. Avoidable!!! Yes. Read on.When you install Windows, by default it is installed on C: drive in Windows directory. And all its successive directories are inside this Windows directory. So, if we reinstall Windows and do not take due precaution we will again use the same Windows and successive directories to install it, thus overwriting the previous ones. And thus destroying our data, as most of it lies in My Documents, including MY Pictures, My Videos, My Webs etc. How to avoid loosing the data? Well, very simple. Install Windows in a different directory, like WINXP or ABCD or whatever you like to name it. And get a new My Documents, My Pictures and so on and so forth. And when the PC/laptop has finally rebooted after the reinstall is over, you can go to the Windows directory and look for your old My Documents etc folders. And you will find that your old documents, pictures, videos and webs are all safe and available to you.One small problem though. Your C: drive may not be large enough for holding two copies of Windows installations. Well, in that case you can install the new copy on a different drive. What will happen is that C: drive would still be used but only for a small percentage of Windows and a huge chunk would be copied/written to the new drive.So, next time you see the blue screen of death, do not panic, just look straight into its eyes and do not shy away from reinstalling Windows.This, however should not lessen the importance of BACKUP. You still have to make a habit of backing up your data regularly. There is no short cut to hard work (read backup).
on Dec 02, 2009 • Computers & Internet
Need to transfer files from old computer to new Hitachi 3 terrabyte drive
The need to transfer files from one hard drive to another is common when restoring from backup, to make more room on a drive by archiving files or to copy or move files to a portable hard drive. Whether the destination drive is an installed second or third hard drive or is a portable hard drive, the procedure to transfer files from one hard drive to another remains the same.
Plug the destination hard drive into the computer if the drive is portable, and confirm that the computer has recognized the hard drive with a pop-up acknowledgment message. Click the "Start" button then click "Computer" or "My Computer," and then double-click on the icon of the hard drive that contains the files to be copied. When a window appears displaying the contents of the hard drive, navigate to the location of the files to be transferred. Click on each file to be transferred while holding down the "CTL" key to select all files to be copied. Right-click on one of the files that has been selected and click "Copy" in the menu that appears if you wish to leave a copy of the files on the hard drive, or click "Cut" in the menu that appears if you wish to move the files instead. Double-click on the icon of the destination hard drive in the "Computer" or "My Computer" window to display the contents of the hard drive in a new window. Navigate to the location on the hard drive where the files are to be saved. Double-click on the destination directory to open the directory and then right-click on blank space inside the directory window and click "Paste" on the menu that appears. A window will appear and display the status of the file transfer and disappear when the file transfer is completed. Hope this helps.
2answers
I use Nero Express to copy personal DVDs. My computer, Windows XP, crashed and when I reinstalled Nero Express. When I now try to copy a DVD the Source disk prompt lists my DVD drive but the destination...
You will have to copy your DVD in two steps. First copy to the hard drive, then remove the source DVD and copy again using the hard drive as the source and a blank DVD as the destination.
1helpful
3answers
NTDLR missing error
option 1: you have to reinstall windows
option 2: take out your harddrive. put it in to a compter with same OS and copy that compyter ntdlr file to c:\
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How do i customize ring tones? (i.e. use my own music, etc.)?
Please find steps to customize ringtones.
Note: in order to be able to use this method one has to have two Motorola phones: the W510 and an older one that isn't ringtone-locked (I tried a V190 and and RAZR V3 and both worked).
First create a backup directory on your drive and call it something like "Original Motorola W510 audio directory". The name doesn't really matter as long as you can find it later if you ever need those files again. Next install the ringtones you want to have on your W510 to the old uncrippled phone.
Then follow these steps:
Step 1 - Connect the W510 to your computer via USB or Bluetooth
Step 2 - Fire up P2K (latest version)
Step 3 - In the right pane navigate to P2k:/c/mobile/audio/ on the W510; in the left pane navigate to the backup directory you just created on your hard drive. It will be empty.
Step 4 - Select all the files in P2k:/c/mobile/audio/, right-click and select "copy", the files will be automatically pasted in your backup directory.
Step 5 - Delete all the files in P2k:/c/mobile/audio/. Once this is done the "audio" directory will have vanished so it's possible that P2K will crash, this is not a problem.
Step 6 - Create a new directory on your disk, name doesn't matter. Unplug the W510 from the computer and reboot it (the phone), then close P2K (if it hasn't crashed already) and plug the older Motorola phone into the computer, wait for the computer to recognize the new phone, then restart P2K. On the right pane navigate to the old phone's audio directory (same location as on the W510), on the left go to the new directory you have just created.
Step 7 - use the method described in Step 4 to copy all the files in the audio directory to your hard disk. *Do not erase any files in the old phone's audio directory*
Shut P2K down and unplug the old phone from the computer. Plug in the W510 and wait for the computer to recognize it. Once this is done fire up P2K once more.
Step 8 - Remember that the audio directory on the W510 is gone, so you can't navigate directly to it, you need to create it first. In the right pane go to /c/mobile/ and select "New Folder" from the menu at the bottom of the pane. Name the new folder "audio" and navigate to it.
Step 8 - In the left pane navigate to the new directory on your hard drive that contains the audio files from the old phone.
Step 9 - Copy all those audio files to the new audio folder you just created on the W510.
Step 10 - That's it, your W510 now contains every single ringtone that was on your old phone and all of them now have the "apply" option enabled so the W510 will now accept any of those sounds as a ringtone.
Unfortunately the W510 still won't accept sounds from any other source than the old phone but as long as you're able to get those those sounds (inclding custom sounds) to register as ringtones on the old phone you'll be able to transfer them to the W510 using the method described above. It's a little tedious but there ain't no such thing as a free lunch is there
Thanks
S
1helpful
3answers
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
I tried to reformat a disk drive by re-installing Win XP but it still have left some old files in the directory..i want to make a good disk drive format as in..virgin..is that possible? osr
When you attempted to reinstall Xp did you answer to install on a new particion or fix and repair existing? Reparticion hard drive or you can download a program ferom one of the hard disk makers such asWestern digital , reformatt the whole drive with that then reinstall windows.
2answers
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
System wont boot up
Have you done any setup to the new hard drive? Any new hard drive will come with no data on it. This means you will have to reinstall windows onto the new hard drive, or copy windows from your old hard drive(if it still boots up) using the CD that came with the hard drive. If your hard drive didn't come with the software, post which hard drive you have, and I can give you the link to download it.
Try and find the Windows CD's that came with your computer, and use them to reinstall it. If this was a name brand computer (like dell, or HP), then it will have come with some CD's (usually). Sometimes the restore is built into the old hard drive :-)
If this was a clone computer, you should have a legal copy of windows that was given to you.
Open Questions:
Top Trilogy Locks & Locksmithing Experts
john h
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
