AMT Datasouth Aries MK238 Weapon Sight Logo
Posted on Jun 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Put in battery and light comes on but nothing happens, i have a aries mk 238
Anonymous
Level 3:
Master:
  • Master 577 Answers
  • Posted on Aug 03, 2011
Anonymous
Master
Level 3:
Master:
Answers
577
Questions
0
Helped
218662
Points
1089
Jeepers! I have work on these ATN MK238 before. All internal electronic are made in Russia. There are two major problem with them. Image intensifier tube goes lights out, the ccfl inver, coil and voltage multiplier are seal in dielectric jell and epoxy. can't work of them. I can work on them, but I am not. Who ever work on it will need to install a new image tube, manufacture ccfl inverter, fine a coil and manufacture voltage multiplie and get the correct cathode ingnitor voltage, hard.
Sorry, I wish you all the luck. They one more option send it ATN and before you send it call ask what the price will be, and get the guys name or record it. stewbison
Tascam 238 recording deck won't stop rewinding.
Well which is it 122 mk III or the 238?
The grease in the 122 will harden with time and gear crack or lose teeth. The deck needs to be worked on. There is myself in Chicago,
Russ in New Jersey that are still working Teac Technicians. There is Adrian in CA but I am not sure he wants to work on cassette decks.
I have an Aries mk 208/230? night vision sight that's been sitting in the closet for several years. I put the batteries in it and it failed to work. I bought a new battery for it and it still does not...
As you probably know that internal electronic are manufactured in Russia. I just repair an ATN MK238. Verything from the image intensifier tube to power supply was shot. I managed to round up 1 gen green Russian image tube, but the ccfl inverter, tolorid coil, voltage multiplier I had to manufactured them. Sorry, wish that I could be more help. stewbison
Lens diagram aries 238
Hi, the objective lens on this ATN MK238. Now these lenses are Russian Optics and they manufacture very good to excellent optics. Take the lens to a camera shop, if they can fix it, then they will know who will. If you send it to ATN they just throw away your lens and replace it with a new lens. If you are going to replace the lens then up grade to 90mm to 100mm lens, OK. stewbsion
HAVE ARIES MK 238 BUT CAN'T SEE THREW IT,IT HAS A NEW BATTERY.
Sorry to tell you. The image intenifier tube when south with Russian timing. I have picture of the image tube but i can't figure out how to load them here. What are you going to do with the MK338. GB....stewbison
if the eye tube is not lighting up its likley to be the censor burnd out or the tube is broken,,, dont use it in full day light,,
Nite Vision scope
Unscrew front lens front of intensifier tube should have an even bronze tinted coating on glass if it is grey and blotchy the tube is degassed. common fault with this model nightvision
wayn
Mk6500 weapons site
this is a common power supply fault it is encapsuled around 2nd gen tube can be replaced but hard to get new supply and not easily removed from tube encapsuled in silicone
wayne
1helpful
2answers
Amt aries mk238 model#500433
I have a Amt aries 208 I have changed the battery but i cant get to do any thing . and i have lost all of the manuals can you help.Ed.
Top AMT Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an AMT Optic Expert? Answer questions, earn points and help others
