Question about LG Televison & Video
I have a 26" flat
  • LG Master
  • 6,993 Answers
yes, it could be a power surge,
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on Jun 07, 2011
6ya staff
SOURCE:
Screen lights up and then goes black
sounds like a coil break down under heat. It is a common fault. You will need to get it fixed at your local dealer or a repair shop.
Nov 24, 2012 | LG Agf37000701 Main Board For 26lg30-ua
I have a 26LG30-ua T.V flat screen has sound but no picture. Plz help thanx
Contact the nearest authorized service center for LG at your area.
Aug 20, 2012 | Televison & Video
Flashing blue red
Switch off the TV manually, switch off the power outlet, remove plug and retry after 48 hours. Then if the problem persists, this might need attention by a qualified service technician.
Jul 24, 2012 | LG 26LG30 26 in. LCD TV
Lg mod 26lg30-ua picture is too dark and brightness adjustmen does not help
I suspect that you have a backlight issue. The backlight is not getting sufficient voltage usually due to a malfunction of the 12V line on the power supply board of the tv or a faulty backlight inverter board. This issue cannot be narrowed down any further without testing it. So if you are handy at fixing electronics stuff and know how to use a multimeter then let me know and I will guide you.
Apr 04, 2011 | Televison & Video
I'm trying to connect my desktop Dell (PC) to my 26LG30 tv. When I start it up, all appears to go as normal - and then it goes to "invalid format" on the screen. I've set the TV input to RGB-PC and...
Try to reinstall the video driver for the desktop. you can download the drivers from http://support.dell.com
Also flash the bios of the computer by download int the file from the above website.
and also try to change the resolution by connecting to a monitor and try connecting to the TV ..
Dec 26, 2009 | LG 26LG30 26 in. LCD TV
LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | LG 26LG30 26 in. LCD TV
Lg 26lg30 light blinks red blue wont turn on. When unpluged light flashes blue for a minute then turns off
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
Nov 06, 2009 | LG 26LG30 26 in. LCD TV
Televison & Video Logo
233 people viewed this question
Ekse
RONALD CARTER JR
