Please make sure that the Standby light or the Lamp light of the TV is blinking. The light blinking of the TV indicates to the service code and be easily identified with the help of a service technician. If the Lamp light of the TV is blinking, then it indicates that the Lamp requires a replacement. The TV will cycles on standby mode if there is any internal malfunction in the TV.
You can try removing the connected devices from the TV to check if the issue is with the connected devices.
Turn the power of the TV to off and remove the power cord from the wall outlet.
Reconnect the TV directly to a working wall outlet and check if it works. Please remove any power surge protector if connected.
Also make sure that the TV is properly ventilated.
If the issue persists after the troubleshooting steps, then service may be required.
Thanks for contacting FixYa.
Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
