Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP:
First right-click on the desktop and then left click on
Properties from the menu that appears.
The
display properties dialogue box will appear as shown in
fig 1.1 below, click on the
settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options
you have will depend on your graphics card and monitor, but the
standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor
loadTOCNode(2, 'summary');
- Click Start, click Control Panel, click Appearance and Themes, and then click Display.
Alternatively, right-click the desktop, and then click
Properties.
- Click the Settings tab, and then click Advanced.
- Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
- The default refresh rate setting is 60 Hertz (HZ); however,
your monitor may support a higher setting. Check your manufacturer's
documentation for information about the settings that your monitor
supports.
- If you use a higher refresh rate, you can reduce the rate
that your screen flickers; however, if you specify a refresh rate that is too
high for your monitor, your screen may become unusable and your hardware may be
damaged.
- Changes to the refresh rate affect all users that log on to
the computer.
Source:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
http://support.microsoft.com/kb/311403
Kindly rate me if i was helpful.
Regards,
Waqar
watch out for hidden sleep here.
it never lies to you this. ever.
time for newer better monitor.
turn off sleep timer in oSD menu here.
out of range means.
PC is sending H/V signals and resolution out side legal range of the monitor.
so it can not function at all.
the cures are only 2.
1: buy newer monitor.
2: or change your PC to different resolution range.1280 x 1024 at 75 Hz (or 60hz)
to not exceed 1280 HOrz/
set PC to 1280 x 1024
done.
or upgrade to newer monitor.
like car fast with bicycle tires fitted
same deal. (time for real tires)
