Question about Zebra Computers & Internet
I want to print barcode 128 with lp2844 zebra, when I send comands via printer object like below code in vb6, nothing happend and the code will be printed like as a string. my question is how to send command to this printer and using internal barcode 128 printer.print N printer.print B1,5,0,1,1,7,40,B,"123456" printer.print P1
Posted by mh_fadaei on
3 Related Answers
Anonymous
SOURCE: Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
Posted on Feb 20, 2009
Anonymous
  • 38 Answers
SOURCE: Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Posted on Jan 06, 2010
pkwc
  • 254 Answers
SOURCE: I have Zebra LP2844 printer
To send text to printer in dos command you should first install a driver from
www.seagullscientific.com
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
Posted on Aug 12, 2011
Hello I was working on Zebra LP2844 label printers. I need to print labels and barcodes from a data source using EPL.I have never done this things before so any help is appriciated
Epson standard code is totally different. EPL is Eltron printer language. I've not programmed in it, but there should be a programmers manual out there somewhere.
Jul 29, 2015 | Zebra LP 2844 Thermal Printer
I have Zebra LP2844 printer and Windows Vista OS. I have installed Zebra LP2844 and ZDesigner LP 2844 drivers and I want to use ELP to print text, barcode etc. Printer is connected to computer via USB. How...
to send the file
hope it helps
Aug 01, 2011 | Zebra LP 2844 Thermal Printer
Zebra LP2844 print is wrapping horizontally
Update the printer firmware, download latest printer driver from zebra website.
Oct 01, 2009 | Zebra LP 2844 Thermal Printer
I'm inputing ASCII via RS232 would like barcode printout
You will need to send the data using ZPL or the printer won't recognize it , if you don't have experience in this area print through the Zebra Print Driver should work. In your application use Barcode 128 as the font and see how it goes
Jul 24, 2009 | Zebra Z4M Printer
I have Thermal Zebra Printer TLP2824, I have installed it and
download.....http://www.barcodesinc.com/free-barcode-font/
free barcode font for programs. copy into c:/windows/fonts
it will install into that folder, and just select that font in VB6 application before printing
May 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
I have sato cx400 printer, looking for VB6 code
Try this link:
http://www.filebuzz.com/files/Codabar_C/freeware-1.html
Have a look at the VB Barcode Integration Kit
Feb 04, 2009 | SATO CX400 Thermal Label Printer
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
Jan 08, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Computers & Internet Logo
102 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
