Getting error code E13 1037912 on the Juki SC-1 type FB controller, machine is model DDL-5550N-7 can anyone tell me what error code means and if there's an easy fix?
Posted by tvarble on
  • Mobley Apr 03, 2012
    I am having same code displayed , any solutions would be appreciated . thanks RJ
  • Khanh Trinh
    Khanh Trinh Dec 21, 2013
    Hi , Motor not Run
FalDiz
That just happened to me did you ever find out why? :( please help!!
Posted on May 06, 2012
My machine give error E-6
hi there
error E-6 means your control box is older than machine model DDL-8700/7. please tell me your control box model and i can help.
best regards
ASHRAF
CAIRO - EGYPT
[email protected]
Jan 08, 2014 | Juki DDL-8700
Problem with Juki DDL-5550N-7 Sewing Machine, Error Code E24
El Drv se refiere a la tarjeta interna que controla el motor, est? se encuentra da?ada.
Email: [email protected]
May 11, 2012 | Juki Sewing Machines
Some times Error-2 & some times error-4.Our model is JUKI8500-7.Control box model is SV500 series. Pls advice the soluations. Regards, Kailash [email protected]
hi there
1- your control box model is SC-500 not SV500, juki didn't made sv never ever
2- there is no error 2 just error 3 and error 4 both means there's problem with synchronizer which installed behaind handwheel first try to clean it by dray spray maby there's some oil or dust arround it. if error still coming change the senchronyzer with new one
best regards
ashraf abozid
[email protected]
Sep 03, 2010 | Juki DDL-8700
Where does the oil go in my Juki DDL-5550n-7 sewing machine? I lost the manual and I don't want to buy a new one just for this one thing. Thanks.
hi there
here's the type of oil u need for juki lockstitch machine
( juki Defrix oil No.1 ) you cand found in your local market if NO u can buy light oil white color for industerial sewing machine
best regards
ashraf abozid
Aug 17, 2010 | Juki MO-644D Mechanical Sewing Machine
Juki 5550n-7 error code e26
hi there
this error means 24 volt power supply has short circuited plase try to check fuse no 4 if this control model SC1 or SC2
best regards
ashraf abozid
[email protected]
Aug 06, 2010 | Sewing Machines
I have a DDL-5550N-7. It is connected to a Juki SC-1 type FB. Everytime I push the pedal its stops, beeps and on the screen it says E 7 660865. It will not work after that. I need to disconnected and...
Per the SC-1 Engineer Manual:
Error Code E7
The motor has locked. (The motor fails to rotate with controlled even when the motor has been driven.)
Check whether the sewing machine head has locked. (Is is possible to trun the pulley lightly by hand?) ** Correct the swizure of ther machine head.
Check whether the tread has been tangled in the pulley of the sewing maichine.
Check whether the thread has been tangled in the motor pulley shaft.
Check whether the thread has been caught in the hook.
Check whether the proper amount of oil is supplied to the hook.
My guess is your hook and cutter are stuffed with thread and thread dust. Remove the cover plate (2 screws) and the feed dog (2 screws) and carefully clean the junk out. You also likely have thread wrapped aound the shaft behind the bobbin assembly. I use a seam ripper to get that thread out.
Feb 01, 2009 | Juki DDL-8300
Error message on screen.
yes, the control box for sc-1 is damage that is why you getting E7.that need some repair.or you can ask at [email protected] for service.
Computers & Internet Logo
333 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
