Question about Norelco 3605 X Electric Shaver
I was given a norelco 3605 shaver in excellent condition (used) without instructions and would like to know the charging procedure and duration (the amount of time it takes to fully charge the razor). Is it possible to overcharge or can I leave the shaver plugged in when I am not shaving.
    New Friend:
The manual says to charge for 16 hours if it has not been used in awhile. They say nothing about it over charging, but the batteries need to be used and let discharge through shaving. A fresh/new battery is supposed to last about 2 weeks before needing a recharge. I think keeping them charged all the time cuts down on battery life.
Posted on Jul 14, 2011
6ya staff
SOURCE:
I got a norelco 3605 x shaver from US. what is d input voltage to charge
There is a red switch on the bottom that allows you to switch the voltage from 120V to 240V
Oct 02, 2014 | Norelco 3605 X Electric Shaver
How do i replace a battery in a norelco 4604x shaver
The correct battery can be found at shaveroutlet.com here:
http://shaveroutlet.com/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
Disassembly video is here:
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Sep 21, 2014 | Health & Beauty
Which shaver replaced the Norelco 3605x
philips norelco HQ56 replacement heads for electric shaver norelco 3605x blades replacement parts.
Nov 24, 2012 | Norelco 3605 X Electric Shaver
My shaver appers to be dying. It doesn't hold a charge anymore and lacks the power that it used to have so it catches my beard. Should I replace the battery or is it ready for scrap?
The battery for model 3605X can be found at shaveroutlet.com for a price of $12.49. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-pack-fits-norelco-3605-others-p-277.html
To replace, start by removing the 4 screws on the back and then removing the back cover. You can then access the battery. For easiest replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Mar 18, 2011 | Norelco 3605 X Electric Shaver
Won't hold a charge
Most likely, the battery is dead. To change the battery on model 3605X, you need to remove the back cover by removing the 4 screws. You will need to extent the long hair trimmer to reveal 2 of them. Once back is removed, you can access the batteries. You may find it easier to work with if you remove the 'guts' by taking off the two clips that hold the motor to the shaver. You can then lift everything out.
Simply unsolder the old battery and solder in a new one. Reassemble in reverse order.
You will find this battery at shaveroutlet.com. See link below
Sep 18, 2010 | Norelco 3605 X Electric Shaver
Replace battery
It is a #8 torx screwdriver. if needed, you can purchase one from shaveroutlet.com. See link below
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Feb 27, 2010 | Norelco 3605 X Electric Shaver
Norelco shaver 4825XL
I was given a Norelco 4825xl shaver without the instructions booklet. What do I do to switch beetween 110V and 220V for Overseas and US use.
Thanks
John
Jul 19, 2008 | Norelco Micro Action Shaver 4865XL...
Norelco 3605 X Electric Shaver Logo
236 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Robert McClure
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
