Question about Eddie Bauer Musical Rocking Bassinet 10330WOW Crib
Dont know how to remove the bedding from the bassinet to wash
Posted by bnesrgn on
Kandi Cook
  • 823 Answers
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Posted on Jul 08, 2011
Removing fabric for washing
Hi! Were you able to figure it out? I am having the same issue and it is driving me nuts! Lol. I dont get hoe the instructions dont provide details for fabric removal! Please let me know if you were able to get it off. I got mine second hand and it is filthy. :(
Feb 14, 2012 | Kidsline Premium Bebe Fina BF9111 Crib
I have vicki 4 in 1 convertible bed.i dont have the manual
Hello! This is Products America. We service most crib hardware. The number to Sorelle is 201-531-1919. You could call them and see if they still have a copy that they could send you.
Oct 05, 2009 | Sorelle Vicki
Bebe Fina bassinet with no instructions--not sure if I have parts
Hi there, I have instructions for a bebe fina bassinet, not sure what model but will fax them to you if you have a fax number, cheers.
Jun 18, 2009 | Kidsline Premium Bebe Fina BF9111 Crib
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
How to convert crib to youth bed..
contact me and i can walk you thru it if it is a white metal one, since that is the one i own and know how to do it
Jun 29, 2008 | Simplicity for Children 4-in-1 Convertible...
It was bought at a yard sale.....
hi. i have those directions. i have model no. 3013 pro. this can be found on the mattress support. if it is the same type of bed attachment, then here are the directions (if it isn't the same then it gives you a general idea of how it works)
converting to a bedside sleeper
remove canopy from bassinet.
unsnap the fabric and remove the removable cross tube from the bassinet frame
fold the Velcro panel down over the support bar and tuck under fabric bottom
position the retainer plate on the side of the bed opposite where the bedside sleeper will be, thread the retainer strap through the space between the mattress and box spring. make sure retainer plate is vertical and flush against the mattress and box spring.
connect the strap ends to the snap connectors on the support tube. bassinet must be pulled snugly along side of the bed.
if that isn't right, here is their support number: 18008588323.
hope it works.
Jun 26, 2008 | Simplicity for Children 3 in 1 Convertible...
Getting the canopy off to wash it
Remove/losen the velcro for the bottom of the bed . There are three screws on each side of the base were the music box and volume is. You want to remove the MIDDLE screw ONLY on each side. On each opposite end of the base is a large screw and on the other side is a smaller screw, unloosen the screws and the base of the bed fall off so that you can remove the lining. Remember you only need to remove the middle screw.
Jun 25, 2008 | Eddie Bauer Musical Rocking Bassinet...
Bedding
I got this bassinet 2nd hand. I can tell you that I did wash the whole set. You have to take the screws out at either end to remove the cover (one screw is behind the batteries in the music box). I removed the plastic parts (the slits are closed with velcro for the flat plastic panels so the plastic simply slides out). The hoops were a little more difficult but since it is an overlap closing and the hoops are flexible, you can remove them. Simply wash in cold water and hang to dry. When its dry, you can put the plastic slides and hoops back in the same way you took them out. Came out fine.
Jun 19, 2008 | Eddie Bauer Musical Rocking Bassinet...
Washing the bedding
no. wash the canopy manually.. soak it in soap and water then rinse.
Jun 18, 2008 | Eddie Bauer Musical Rocking Bassinet...
Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Logo
Top Eddie Bauer Baby Gear Experts
tina gallow
Paul Bade
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
