Canon Powershot SD450 / IXUS 55 Digital Camera Logo
Posted on Jun 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the canon powershot sd450 compatible with windows 7 operating system
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Jun 07, 2011
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428623
Points
622693
The camera doesn't care what operating system you have on your computer. It'll work fine with no computer at all, for that matter.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
2helpful
Windows 7 will not recognize the camera. Canon website says there are no drivers for the camera.
images can be viewed using memory card only on Windows 7. This requires your computer to have a memory card reader that you can insert your Camera's memory card into. If your printer has a memory card reader, you could use that as well.
If you want to use the camera with a USB cable, you will need another computer with Windows XP installed as the Operating system, or you will need to purchase a newer camera that is compatible with Windows 7.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Powershot A470. used to be able to download pics with no prob to my computer. Got a new pc Samsung with windows 7 (RV510) but for some reason it cant download to my old pc either.. just seems its not...
Windows7 usually use x64 bit system operation, drivers which run in windows XP or Vista can be uninstallable in Windows 7 because XP and Vista use x32 bit system operation (except certain series).
See your OS from Device Manager (Windows+PauseBreak > Device Manager), 32 bit or 64 bit. Then you can download the driver compatible with your OS from here :
http://driverscollection.com/?H=PowerShot%20A470&By=Canon
If this useful, RATE please !
3helpful
Powershot s40 drivers for windows 7
There in no need to download driver explicitly, As driver comes inbuilt with your Window 7 operating system, you need to connect your device (Camera) with the computer through data cable and just need to follow the instructions.
For more information visit this link
Have a nice day
Rating the solution is highly appreciated.
1helpful
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
2answers
I'm using windows 7 but it cannot find the driver
Windows Vista or Windows 7, will have problems running some older versions of applications, just because so much has changed under the hood from Windows XP days. Thankfully there is a compatibility mode that can be easily set per application.
To configure the compatibility mode for an application, just locate the installation directory and right click on the .exe, selecting Properties from the menu.
Select the Compatibility tab:
You can choose to run the program in Windows XP compatibility mode, or even all the way back to Windows 95 compatibility.
Probably the most useful setting to start off with would be to disable the visual themes and desktop composition, if you can’t get things working. If you are trying to run a video game, you will often need to choose “Run this program as an administrator”. You’ll have to play around with it, but most likely you can get your application working this way.
Cannot download pictures using zoom browser ex with my camera Canon SD450 in my Wwindows Vista laptop. Laptop doesn't open automatically the download window as in with XP. Also, I cannot open Canon Camera...
Camera direct to computer connections are notoriously problematic. (Lousy with bugs etc.) I avoid the problem entirely by using a card reader ($15-20) combined with Picasa3 (free software from Google). Remove card from camera and insert into card reader, connect to computer via USB and download images with Picasa3. Works great and is relatively cheap.
1helpful
My Powershot 450sd camera is not reading 4GB SDHC
Apparently IXUS 55 is not compatible with a 4GB SD card. Use a 2GB and you would be fine.
I cannot figure out how to turn off the flash on my canon sd450
You first need to change the operating mode to Manual. Then you can change the flash by pressing the right button a few times.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
