Dell Inspiron 545 (884116037743) PC Desktop Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My desktop froze on the screen saver, picture slide, could not be turned off in any other way but by pressing the off button. Then , it doesn't turn on. Once, on the advise of a friend, I was able to turn it on by pressing simultaneously the on button and F8, now that doesn't work either. Please advise
Steve Nordquist
Level 3:
  • Master 982 Answers
  • Posted on Jun 06, 2011
Steve Nordquist
Master
Level 3:
Answers
982
Questions
Helped
213518
Points
2276
Power supplies go bad over time, but it's also possible some card fell out of place inside there. Open it up, use the brush attachment on the vacuum to dust it out as necessary, make sure the cards, memory and heatsinks are seated securely, and try again. It's easy to buy a new power supply at NewEgg or locally; you want around 300-450W unless you bought dual videocards (then up to 650W.)
My screen saver doesn't come out
Hi easparkman...
You will need to go to:
Start>Control Panel>Appearance and Themes>Choose Screensaver and then you can pick the screen saver of your choice.
Please take time to rate me
tip
Create A Personal Screen Saver In Win Xp!
This isnt a tweak, but a great little feature! For a great way to put your digital photos to work, try creating a slide show presentation for use as a screen saver. Here's how:
1. Right-click an empty spot on your desktop and then click Properties.
2. Click the Screen Saver tab.
3. In the Screen saver list, click My Pictures Slideshow.
4. Click Settings to make any adjustments, such as how often the pictures should change, what size they should be, and whether you'll use transition effects between pictures, and then click OK.
Now your screen saver is a random display of the pictures taken from your My Pictures folder.
on Oct 09, 2010 • Computers & Internet
tip
Create a Personal Screen Saver in Windows XP!
1.) Right-click an empty spot on your desktop and then click Properties.
2.) Click the Screen Saver tab.
3.) In the Screen Saver list, click My Pictures Slideshow.
4.) Click Settings to make any adjustments, such as how often the pictures should change, what size they should be, and whether you'll use transition effects between pictures, and then click OK.
Good luck & Have Fun!
on Jan 26, 2010 • Computers & Internet
2answers
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
2helpful
2answers
How can i save a picture as my screen saver
Assuming you are using windows XP on this:
Create a new folder in "my pictures " folder
Copy the images you want to use into there
On your desktop, RIGHT click and choose "properties" to open the display settings
Click "Screen saver" and choose my pictures slideshow
Click "settings" to open the options for this
Click browse to point to where you saved the images
Set the duration and timings to suit your tastes
Exit by clicking Ok and the OK to exit the display settings
tip
on Dec 05, 2009 • Computers & Internet
1helpful
3answers
Created a 300 picture slide show on my pc. the screen will go blank after 30 minutes and i have to hit the return key or touch the pad. Is this a sleep setting issue or kodak?
I suspect you have a screen saver set up that blanks the computer screen after 30 minutes.
If you are running Window XP, right-click your mouse on the desktop, choose Properties, from the Display Properties dialog, click the Screen Saver tab, then in the Wait box, increase the amount of time before the screen saver activates. Click the OK button when you are through.
Good luck,
-- SalParadise
Feb 28, 2011 • Cameras
Screen savers
Go to Control Panel choose Display Properties go to Desktop tab there is a selection from Position: center, stretch, tile choose the stretch then apply and ok, your picture will displayed in full screen in your desktop
I need to restore icons on desktop, tried to do so, nothing works. The screen saver has covered the entire desktop face. cannot remove it.
I am not sure that the screen saver is making problems.
Screen savers turn on after at least one minute of no activity, and turn off when you move your mouse or press a button on your keyboard.
Start your PC in 'SAFE MODE' . Are there your desktop icons?
Disable or uninstall the screen saver and and restart in 'Normal mode'.
Regards.
A blue screen appears in the place of my screensaver.
i) whenever u keep ur system idle for few minutes or longer time ur system goes in screen saver mode, in order to know more about it......
Screen Saver Mode: when u keep ur system idle for few minutes(say more 10 min or any or u might u kept system idle while you some work to doo...) in such a case u will have graphical picture of a blue screen evolved on your screen, you can even changethe picture or screen saver and keep your own.....
right click on desktop(close all the windows) and select the button Screen Saver and configure to apply your own screen saver(try to explore and learn about it....
Thankin you
M. Sridhar
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
