Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Laars Lite 2. Pool an spa heater Model LD25ON. Nat. Gas It was working and then shut off. The pilot generator glows, but it never fires up. I have bypassed the pressure switch and still nothing. I did here clicking. I also by passed the thermo coupler also clicking but nothing fired up.
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Teledyne Laars Master 1,448 Answers
  • Posted on Nov 06, 2014
David Spradling
Level 3:
Renaissance:
Answers
1448
Questions
Helped
518473
Points
1901
See if 24 volts ac to the brown and yellow of the gas valve if voltage need new gas valve if no voltage need new fenwal
5 Related Answers
Anonymous
  • Posted on May 25, 2009
SOURCE: Laars lite II Pool and spa Heater LG model
Bad pilot generator? Flow issue?
Anonymous
  • 83 Answers
  • Posted on Jul 08, 2009
SOURCE: I have a Laars Lite 2 400,000 btu pool heater. It
It could be that the Igniter has gone bad. Or it cold be a number of other items, like the gas valve itself. If the heater has a display panel on it, is there an error code showing? If there is, go to your Owner's Manual and find out what the code is for the heater.
If you do not have a manual, you can find one online at the following link:
http://www.inyopools.com/owners_manual/jandy_heaters_lite2.pdf
Anonymous
  • 112 Answers
  • Posted on Aug 31, 2009
SOURCE: Millivolt pool heater will not ignite
Most heaters do not require power for the pilot to remain lit. Is there power at he unit? If it worked yesterday and not today has anyone turned it off at the circuit breaker? If you have power turn the gas valve off for 10 minuets and then relight to see if it needed a reset.
Anonymous
  • 990 Answers
  • Posted on Dec 01, 2009
SOURCE: Laars LX400N with LCD display. Display not
You will probally need a new board but that is hard to say without being there. As far as the replacement goes;don't let all the wires fool ya. Each set of wires has a set number of pins it fits so not only is it difficult to get them wrong but when you put the new board in place the wires will have a memory to them and fall into the place where they hook up. Nothing to it, but get a book and be sure that you need the board first as they are pricey.Good luck
Anonymous
  • 3 Answers
  • Posted on May 29, 2010
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Pilot and heater works for about 2 min and shuts off heater and pilot
check gas pressure if too small a line that will happen or too low gas pressure
Every year I have a problem getting it to light. The pilot is lit but the heater will not turn on. It is 8 years old and I have been having trouble with it since day one. My pool guy comes out fires it up...
First, check the gas valve and make sure the valve in all the way to "on" not "pilot".After shutting to off for the winter, and not turning the valve all the way on start up could be it. If that is ok, check/replace the pilot generator next to the pilot lite. One question. Does the pilot go out soon after calling for heat? Next, if you have it on "spa" or "pool" on the temperature adjusting module, try the other setting. eg. If it is on "pool", switch the knob to "spa" and adjust the temperature.
2answers
Pilot lights but burner will not fire
what burner where on the oven or the cooktop, if its the oven it may need new gas valve w\ thermocoupler
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
deton8 von Splosion
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
