Question about Bosch Logixx WAS2446 Front Load Washer
Hi I have a Bosch Logixx 8 washing machine that
Hi I have a Bosch Logixx 8 washing machine that started showing an F27 fault when it finishes the wash. All works OK apart from displaying F27 at the End of the cycle. Difficult to open the door! Does anybody know what F27 means? I cannot find it in the Bosch Manual. THANKS in anticipation Chris
Posted by chrisliassid on
Eric Taylor
    Master:
  • 590 Answers
Go to the manufactures website and download the user manual giving the model nr eric
Posted on Jan 20, 2018
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
Anonymous
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Posted on Feb 19, 2010
Testimonial: "thanks-- how do you know how much soap is enough?"
prem mathew
  • 662 Answers
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your pump/filter is plugged. (E4) There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem. When the water is drained in machine the door is open able.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate. I will try to come back to you re. the wash, wash.
Pl rate me 'very helpful' for the free help, thanks!
Posted on Jun 17, 2010
Roni Davey
  • 414 Answers
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Posted on Jul 07, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: bosch logixx 8 washing machine showing F37
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
Hi. Have a Bosch Loggix 8 VarioPerfect WAS32440AU. It has been displaying a uPd code. Was hoping that you can verify the issue. TIA Brian.
First, of all it is a Bosch "Logixx".
Not a whisper of your fault code anywhere... go to this site and towards the bottom you will see a FORM to ask directly about your specific model AND your exotic fault code! Are you sure you have that "code" right?
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3310-bosch-logixx-was-series-washing-machine-error-codes
Then I found THIS bad news!
"There are a number of different version of the electronics used in Bosch Group made washing machines and washer dryers that are sold as Bosch, Siemens and Neff and most of them use the different fault or error codes when they have a problem or a spare part fails. This particular article relates especially to the range of Logixx washing machines that have an ENR number in the format of WAS****GB/** where the asterisks replaced by a number for each one."
Find a long list of fault codes here:
http://www.drdishwasher.com/troubleshooting/manufacturer/bosch/error-codes
Yours is not on the list? Still sure about that number?
Anthony
Apr 02, 2018 | Bosch Washing Machines
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
Bosch washing machine (logixx 8) shows error code F57
The E57 error code on the Bosch Logixx 8 means that there has been a door lock fault.
Feb 13, 2015 | Bosch Washing Machines
Bosch Logixx 8 with a f27 error- what could cause this?
The code means that the pump out pressure is to high
this can be caused by a partial blockage in the filter, the pump, the hose to the drain or by a drain hose that is to long or up to high above the washer
it can also be caused by excessive foam
Dec 07, 2014 | Bosch Washing Machines
NrO fault code on bosch logixx 8
nrO is child lock. Hold start button for 5 seconds to remove.
Dec 07, 2012 | Bosch Logixx WFT 2806 Front Load...
F27 fault on bosch logixx 8
F27 is a problem with the pressure switch
Nov 04, 2012 | Washing Machines
Bosch Logixx 8 - unblocking pump/removing front panels
Bosch Logixx 8 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 30, 2012 | Washing Machines
I have a Bosch Logixx 8 Vario perfect washing machine. Its only a few months old. My problem is that the conditioner is still in the drawer after the wash is finished. What do I do
Bosch Logixx 8 Vario problem is that the conditioner is still in the drawer after the wash is finished This video will show you how to keep your soap draw clear and how to service the parts
Aug 17, 2011 | Audiovox Bosch 718 World Cellular Phone
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Bosch logixx 8 washing machine showing F37
Jan 11, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx WAS2446 Front Load Washer Logo
354 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
