Question about Creda Colonial 42352 23 in. Electric Cooktop
Ignitor on gas stove keeps clicking - Creda Colonial 42352 23 in. Electric Cooktop
Posted by Nancy Pizzillo on
ImJustAvg
  • 2,006 Answers
The model number that you gave is for an ELECTRIC stove, and you are referencing an ignitor on a gas stove. Please take another look at the model number of your unit, so that we might be able to help you solve your problem.
Posted on Jun 07, 2011
1 Related Answer
gerbee gomez
  • 222 Answers
SOURCE: maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Posted on Jul 04, 2009
My GE Monogram Gas Cooktop model ZGU650N4DH5SS ignitor keeps sparking even after the stove is lite. What do I need to change or fix please?
Hi Ishiggs,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Cooktops
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
The large burner on stove keeps clicking away on its own as if you were trying to light it
The ignitor switch for that burner is bad. It is located behind the control knob for that burner.
Jan 13, 2011 | Stoves 23 in. 600GRC Gas Cooktop
GAS STOVE
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 03, 2010 | KitchenAid 32 in. KGCT305GAL Gas Cooktop
Maytag stove top gas ignitor keeps clicking
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Open Questions:
Creda Colonial 42352 23 in. Electric Cooktop Logo
689 people viewed this question
Top Creda Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Creda Cooktop Expert? Answer questions, earn points and help others
