Expert
- Posted on Jun 06, 2011
Re: On previoius Dell products ALT-PRNT SCREEN used to...
Check if you have to press the fn (function) key on your laptop before pressing Print Screen, you can tell if they are both the same blue color.
When you press ALT+Print Screen, you only capture the active window, when you
click print screen you capture the entire screen. Then you will have to
press CTRL+V on your keyboard to paste into paint. If you have windows Vista, you can capture screen shots much more easily using the Snipping Tool included with Vista.
Here's a How to guide to refresh: (Ref: http://graphicssoft.about.com/cs/general/ht/winscreenshot.htm )
- Press the Print Screen key on your keyboard. It may be labeled [PrtScn].
- Open an image editing program, such as Microsoft Paint.
- Go to the Edit menu and choose Paste.
- If prompted to enlarge the image, choose Yes.
- Optional: Use your image editor's crop tool to crop out unnecessary portions of the screen shot.
- Go to the File Menu and choose Save As.
- Navigate to the folder where you want to save the image.
- Type a file name for the image.
- Select a file type.
- Click the Save button.
Tips:
- Hold the Alt key down while pressing Print Screen to capture only the active window.
- Generally the GIF format works best when saving screen shots of application windows. The JPEG format usually makes screen shots (especially those with text) blurry, blotchy and discolored.
- See related resources below for more screen shot tips
and listings of screen capture software that offers many more options
for capturing screens and portions of screens on Windows and Macintosh
computers.
- The Windows "clipboard" is a term used to
describe the temporary storage space in memory where an item is placed
when you copy or cut. When you paste, the item is transferred to the
program you're working in. If you copy something else, the old item is
replaced with the new. You can't manipulate the clipboard directly; it's
only used for copy and paste operations.
Good Luck
