Question about Yahoo Messenger
Message that d3d9.dll was not found....this is registry error, run reginout cleaner it will fix dll error
Posted by tirik26 on
Amit Pawar
    New Friend:
  • 42 Answers
Download Directx From here and install it.
http://www.filehippo.com/download_directx/download/90ae8f5bd1652097a51c66a550abc588/
If u have any problem let me know.. thank u
Posted on Jul 03, 2011
Skype shows proc address for D3DPERF_setoptions(d3d9.dll)
If you have experienced Failed to get proc address for D3DPERF_Setoptions(d3d9.dll) when you are using Windows XP professional during Skype connection then the following steps are meant for you.
NB: Nothing is corrupted and you don't need to download any DLL file(s) nor run registry cleaner to solve the problem.
STEP I
Uninstall the Skype you installed before. Probably it's the latest with is above your system requirement
STEP II
Download Skype old version 4. To do that Google on Skype version 4 and download it. You can also quickly download it from the link http://www.filehippo.com/download_skype/
STEP III
Install it and run the program the error message will not appear again.
The solution is as simple as that.
Aug 09, 2011 | Computers & Internet
D3d9 not found
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/d3d9.dll/
as I registered few dll's from this site as it is free...worked in my case :)
Feb 17, 2011 | Yahoo Messenger
Failed to get proc address for d3dperf set options d3d9.dll while installing skype
failed to get proc address for d3dperf_set options (d3d9.dll)
Jan 30, 2011 | Computers & Internet
How do i fix: "Failed to get address for D3DPERF
YOu need to update your DirectX. If still the problem exists then use a system utility software to repair your windows corrupt files, registry files and fix different operating system errors. I would recommend you to use system utility software RegInOut. Hope it works for you.
Jan 07, 2011 | Microsoft Windows XP Professional With...
Skype error during installing (d3d9.dil)
there could be a problem with registry keys, run reginout cleaner to fix it
Jan 05, 2011 | Skype IM
Hi i keep getting error messages containing d3d9.dll and d3d10.dll
http://www.fix-all-dll-errors.com/d3d10.dll/
Your faulty d3d9.dll & d3d10.dll can be repaired here...so just go to the link given above.
This will register the dll files on your system.
Jan 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
Error 8007007e
check ur registry setting do this Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll b. REGSVR32 wintrust.dll c. REGSVR32 initpki.dll d. REGSVR32 Rsaenh.dll use reginout cleaner to fix it in easy way
Sep 30, 2010 | Microsoft Windows Live Messanger
When i download yahoo messenger 10 then there is an error of d3d9.dll after installation. pleas give me some solutions
Download the Filehippo software update checker and see if your Microsoft Directx needs updating
http://www.filehippo.com/updatechecker/
Aug 20, 2010 | Yahoo Messenger
D3d9.dll
Well you can download from below, then put it in windows\system32\ Then START>>RUN>>regsvr32 d3d9.dll and enter to "Register" it. Do that as Administrator. www.dll-files.com/dllindex/dll-files.shtml?d3d9
You may have to re-install the application though.
Mar 13, 2010 | Capcom Devil May Cry 4
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Barbat Nae
Barbat Nae
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
