Hitachi 43UWX10B 43" Rear Projection Television Logo
Anonymous Posted on Jun 06, 2011
I turn on my Hitachi 43uwx10b and red light comes on the turns back off and you can hear it click on then off in the back.
  • Anonymous Jun 11, 2011
    What do I need to replace on the board
  • Anonymous Jun 19, 2011
    Still didn't fix my problem though. So what else could it be. I read about the voltage regulator by the red light going bad. So ordered it and going to replace it this week. If its not that then what else could it be
Kenneth Lee Sr.
Level 3:
  • Master 597 Answers
  • Posted on Jun 10, 2011
Kenneth Lee Sr.
Master
Level 3:
Answers
597
Questions
10
Helped
82818
Points
1207
Replace power board. Try Encompass Parts. I own this model
  • 2 more comments
    What part on the power board needs to be replaced. A relay or what.
  • Kenneth Lee Sr. Jun 11, 2011
    For a estimate, you could pay up to $110, capacitors , if you are lucky may cost $20. A rebult power board may cost $200
    Got lucky. Found a power board on eBay for 45 dollars pulled from a 50 inch working unit. Same board. Same numbers.
    The new board still didn't work. What else could it be? Heard about voltage regulator by red led in back. Ordered it going to change it out this week and if that doesn't work what else could it be?
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
1helpful
I have a Hitachi 43UWX10B that won't turn on. When I try, the red power light flashes, and I hear intermittent chirping. Any way to verify the problem and estimate repair costs?
Your convergence chips have failed.
Sometimes when they fail the TV will look 3D or distorted and sometimes it will just loose video and audio and chirp.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Can't turn tv on
TV DOES NOT COME ON, RED POWER LIGHT BLINKS ON THEN OFF
1helpful
Hitachi 43UWX10B 43" Power Light flashes Continuously
I doubt if its the fuse. We just helped a customer with a very similiar problem. Its more likely that the convergence IC have failed and shorted out. When this happens one of the symproms is that the TV will shut down and chirp. Goto www.TvRepairKits.com and click the contact us button. They can provide you with more instructions on how to test if this is the problem.
Ed
Power light turns on turns off continuously
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Hitachi 43UWX10B
you need the front panel PC board . You can get one most likely at the following link, just leave them an email and indicate your model number and what youre needing they will respond quickly.
http://servicemanuals.vstore.ca/
43UWX10B
It's not coming on probably because the safety sees a short and is sparing you smoke damage. Double check to make sure any solder didn't cross or drop to another set of solder joints on the bottom. You might be able to get a service manual from here that could tell you more about the lights -> https://www.manualsparadise.com/ShowProductsForModel.do?model=M22931911
5helpful
2answers
43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
3answers
Red Power light won't go off
try to unplug it for awhile like all day or do like i have and get one of those really cheep christmas light remotes and put it in line to turn off power and then every time that you turn off your set if the light dose not go out just turn off the power or have a repair man replace your power switch for alot of $$$$$.this work well for my system.
Flashing Power Light
Located in the power supply section of the unit. There is a pico fuse (soldered in fuse) that opens up and there is no high voltage. The second click that you hear when the set is turned on. This can be diagnosed With set unplugged, with an ohm meter with a simple continuity test. I think the pico fuse is 4 amps , I am not absolutely sure. I have seen this problem in that unit previously. There is also a convergence problem that occurs with that set. Scrivitron.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
