Question about Danby Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe the dehumidifier part shuts off one it reaches the programmed level. But the fan doesn't shut off.
Posted by frankdelledo on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 06, 2011
What is the proper setting for Danby R410A?
R410A is refrigerant gas. I think you wanted to know, what humidity extraction level the controls should be set on. If it is really hot and humid in your area, set the humidity extraction level between 35 & 40%. If you have a mechanical control, turn the knob to Maximum.
Hope this helped you, Bradleyjo. Thanks for choosing FixYa.
Aug 06, 2011 | Danby DDR4588EE Dehumidifier
I have a DDR7009EE and the fan runs continuously even when the humidity in the room is below the setting on the machine. Shouldn't the fan stop when the desired humidity is reached?
Lyle, your particular model is designed for the fan to function constantly. However, the fan running doesn't mean the compressor is always running. The reason the unit was designed this way, is for the air to be continually moving, and when the humidity sensor picks up a rise in the humidity level (above where you have it set) the compressor will turn ON and extract that humidity.
Your unit is working as it should. Thanks for choosing FixYa.
Jul 28, 2011 | Danby DDR5009EE Dehumidifier
My Danby DDR583R dehumidifier no longer dehumidifies unless I set the humidistat to the lowest, constant run setting--then the compressor kicks on. The humidity reading says 14% which I know to be...
There are a several things that can mimic a faulty humidity sensor.
1. The air intake filter is clogged and needs to be removed and cleaned.
2. The coiling coils need to be cleaned.
3. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If the above fails to help solve the problem, replacing the Humidity Sensor is certainly an option. But, before you jump into it, make sure you have an accurate wiring diagram, so you know which sensor is which. As the part does not come with installation instructions.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DDR583R Dehumidifier
How to set the controls
Since your Danby, discontinued model has several features that require a picture to understand how to set the controls, as well as how to use the remote control. I have provided a link to your Owner's Manual (in case you have misplaced yours) that you can download and print, for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR586R%20EFOM.pdf
The one thing I would suggest, that you keep in mind is that the lower the percentage of humidity extraction you set it on, the more humidity it will absorb. Which is what you want in the summer. Do Not press and hold the arrow down button. Press it down in increments, until you reach the level you desire.
Hope this helps you.
Jul 13, 2011 | Danby DDR586R Dehumidifier
When the desired humidity level is reached (in my case 50 %), the unit does not go into standby - why is this? It reads 48% but is still running.
I would check the humidity sensor. I think it is located in the return side of that model. It may have trash on it.
Jun 04, 2011 | Danby DDR6009REE Dehumidifier
I have a Danby Silhouette and the fan works but the dehumidifier doesnt.
Bryan, it may imply be a case of the humidity extraction level being set to high. Lower the level to 35% and see what happens. As far as the fan running is concerned. Most dehumidifiers are designed for the fan to run, even if the compressor doesn't turn ON. It's designed to keep the air circulating and if the humidity rises above the setting you have it on, the humidity sensor will pick up this change and turn the compressor ON.
Also, remove the air intake filter to see if it's clogged and needs cleaning. Maintain at least a minimum of 12" of free air space all around the dehumidifier. Poor air circulation will prevent the unit from working properly. As will, to low an ambient air tempeature. Most unit struggle to work at temperature between 40 & 60 degrees F.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 04, 2011 | Danby DDR451 Dehumidifier
Have classic dehumidifier model#CDR4500E. Can't adjust it automaticaly to come on or shut off. Don't understand the keypad fuctions, booklet to confusing.
Your dehumidifier preset default humidity level of 70%. Which is rather high, if you're using the unit in the hot Summer months. You can override this setting and lower the humidity level in increments to as low as 35%. Which is ideal during hot, humid weather. The Air Down button lowers the humidity level.Once the level is set, the unit will cycle ON and OFF as necessary, to maintain the level of humidity.
I have looked at the Owners Manual for you unit, and it's very thorough. But, I can understand, if you're not familiar with how the units work, it could be confusing. Page 5, is very informative on how to operate the unit, as far as setting humidity levels, which is what's important. If the operation of the unit continues to be a problem for you, contact Danby Customer Support 1-800-263-2629 and they can walk you through the procedures, while on the phone with them.
Hop this helped you. Please let me know. Thanks.
May 18, 2011 | Danby DDR2509EE Dehumidifier
My new Danby dehumidifier never shuts off
This unit is designed with the intention of the fan running all the time. The compressor cycles on and off with demand, however the fan runs continuously to provide constant room circulation.
Sep 14, 2009 | Dehumidifiers
Humidty reading remains at 84%
Dehumidifiers are generally a very simple appliance, however a humidistat is one of those items a person tends to rely on to provide feedback. You may want to remove the grille area where the humidistat is mounted and inspect for foreign material in the way of the sensor. If nothing foreign is detected then you should replace the humidistat.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 29, 2008 | Danby DDR586R Dehumidifier - 58 Pints...
Danby  Dehumidifier Logo
399 people viewed this question
Top Danby Dehumidifiers Experts
Vincent G
Vincent G
Sheldon Dedek
Andrew Taylor
Andrew Taylor
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
