Question about Power Dsine Computers & Internet
PD-PH-4006/AC/48-INTR 6 INTERMEC AP 2101B connect to a Intermec PD-PH-4006 (DSINE-POE) From the Data In Ports on the (POE)PD-PH-4006 all 6 AP connect to a 10MB 3COM Switch.All 6 AP have power and working fine. Swap 10 mb 3Com Switch with a Dell PowerConnect 3324 Switch Only 3 AP will connect, I lose 3 AP's No Connection at switch. Swap a AP cable that is connecting at dell's switch with a PORT at the POE and AP doesn't connect. Swap all 6 AP back to the 3com and all 6 AP'S connect. Any input is appreciated. Thank You
Posted by tluna on
2 Related Answers
Anonymous
SOURCE: SD 2008 linksys switch slow
Same problem here - switch appears to revert to 10MB on some ports and 100MB on others. Tried to force 1000 from NIC, but that just lost connectivity - had to reset back to auto to get any connectivity at all
Posted on Nov 11, 2008
Anonymous
  • 97 Answers
SOURCE: Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
Posted on Oct 17, 2010
CK71 stuck on Launching OS
Hi
Please try to Install OS through Intermec Smart System from intermec.com - downloads
and try to install OS via WIFI connection
Note : Make sure about WIFI Connection & Battery Charging power of device
Regards
Aug 22, 2011 | Intermec CK71 Handheld Mobile Computer...
I have a HP ProCurve MSM 410 AP. It will accept clients and then in 20 minutes it starts dropping connections..and will not let them back on with a restart. I have poured over the specs for both AP and...
I'm having a very similar issue with 5 MSM410's (at 2 differant locations), purchased at the same time, from the same vendor.
With 2, when connected using PoE Injector, the AP gets hot (at the Data/Poe port), and only permits 3 devices to connect before the devices start losing the ability comminicate beyond the AP (i.e. I can logon to the AP with the Web Interface (WI), but cannot ping the DHCP server or even the Gateway device on the other side of th AP from the devices, but can ping both directions without issue from the AP's WI). HOWEVER; when connected using the PoE from a Cisco ASA-5505 (port 0/6 or 0/7) the devices work flawlessly.
- For this site, I replaced the Power Injector first, then replaced the AP. No change
- When connected to the PoE on the Cisco the unit does not run "Hot".
With 3 others at another location, they only allow 3 devices to connect and will disconnect any devices previously connected. These 3 are supplied PoE from Dell PowerConnect Gigabit Switches (also used to supply power to the VoIP and PoE Security Camera's), and also run Hot at the Data/PoE ports. We have not tried power injectors at this site.
I've tried to find any indication of how to adjust the PoE and Data Port settings to resolve this, but cannot find anything, and this appears to be a unique issue, as noone I have contacted has ever experianced it.
- Mike
Mar 28, 2011 | HP ProCurve MSM410 (J9426A) Pre-802.11n...
I have upgraded from Intermec 3400 to PM4i
#[56p35-2=ep4=7 -92-4];45b]7m,=0254-80_*!_*
$*_N_)i==/p c5p=s4t][;]4ym= =-o3on4=6zm4][6] 644-3=5]4]y[y]b]]v=-M+2($_)i05-08b -0#5];'[email protected])40igkgpo3]4]'f
Oct 26, 2009 | Intermec EasyCoder 3400 Thermal Label...
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Will not print labels
you have connected two printers on a data switch.right.
1. Print test page through Printer driver.
2. If you are using command for printing on Intermec printer, you should not use generic printer.
3. Interchange the cable connected to printers
May 01, 2008 | Intermec EasyCoder PC4 Label Printer
MAIL MERGER
you have to send the output as such (STX) ESCe5(CAN)(DATA)(CR)(DATA)(CR)(DATA)(ETB)(ETX)PRINT
DO NOT PUT ANY SPACES BETWEEN DATA
LOOK UP SYNTAX AND PRINTING ASAMPLE LABEL IN MANUAL
HOPE THIS HELPS
Dec 04, 2007 | Intermec EasyCoder 3400 Thermal Label...
Computers & Internet Logo
146 people viewed this question
Top Power Dsine Computers & Internet Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Power Dsine Computer and Internet Expert? Answer questions, earn points and help others
