Flatscreen tv digital screen gone blue & unresponsive
My son leant on the remote controller, and has pressed all the buttons trying to refind the digital channels. All we have now is a blue screen and although i have looked thru the manuel to try and reload the digital pictures from set up i can't get set up or anything else to come up on screen...please help!!!!!!
Posted by sunny_smiler on
  • 1 more comment
  • absjbs2003 Oct 11, 2008
    one day i turned on my TV and it was a blue screen w/no response to any button.
  • tictactoe211 Dec 25, 2008
    This has just happened to me too on a new, out of the box Haier HLC22RW LCD/DVD TV. Blue screen with no remote or TV panel control. Please help.
  • Demonic-2011
    Demonic-2011 Dec 22, 2017
    what is the model number and brand of TV?
5 Related Answers
Anonymous
SOURCE: Polaroid HD flat screen TV with DirecTV
Press input and then select dvd. After a few moments the dvd will start up if one is inserted.
Posted on Apr 18, 2008
Anonymous
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
Anonymous
SOURCE: trying to find comcast digital code to use their
10250
Posted on Jun 16, 2009
Anonymous
SOURCE: Panasonic remote and volume/channel buttons do not work
try unplugging while the TV is still on and plug it back after 5 mins and check. it should work.
Mine did. I know this may be a crude method, but it worked.
Posted on Sep 08, 2009
Anonymous
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
How do I program it to a Magnavox tv flatscreen
Programming an RCA Universal Remote - YouTube
? 2:46
https://www.youtube.com/watch?v=MZd4yBivcZ4
Nov 10, 2008 - Uploaded by alpharedecho
... how to program an RCA Universal remote for operation with your TV. ... Still in able to work or my rca flat screen and my zenith. .. ive .... I'd do it over and over and the power button on the remote just turns off in the end?.
Magnavox TV codes - Magnavox TV set. Buy, reviews ...
magnavoxtv.org/magnavox-tv-manual/magnavox-tv-codes/
Helpful Resources for Magnavox TV codes. Press and hold ... Note: If some buttonsdo not operate your equipment, try one of the other codes for your brand. TV.
RCA Universal Remote Control- Target Programming ...
Dec 25, 2015 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
I have the above TV but my fiance accidently leant on the RC & now I've lost the picture.
take the batteries out of the remote and turn the tv on with the set control and see if it goes on
Aug 01, 2015 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
FLM-373B Polariod tv codes
try this:
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • Jun 01, 2010 | Directv RC23 Remote Control
    Pressed 'D/A' button on remote and tv and tv has stopped working
    This is the Digital/Analogue input choice. The TV has probably locked up due to a signal failure, try switching the TV off from the mains electical plug, leaving it for 30 seconds, then plug the TV back into the mains socket & try switching it back on.
    Jul 08, 2009 | Televison & Video
    Child Locked TV and Remote
    Press MENU to show the on-screen
    menu.
    Press VOL+ or VOL- to highlight SET.
    Press CH+ or CH- to highlight
    PARENTAL CONTROL.
    Press VOL+ or VOL- to display the
    SECRET CODE
    screen.
    Press VOL+ (on the remote) and the
    CH+ button on the front of the TV
    at the same time.
    Press the Number buttons to
    enter a four-digit code. The code will
    appear on the screen as you enter it.
    The code "0000" is the default of the
    TV. If you have not set up a code previously,
    then "0000" is the code.You cannot
    use "0000" after you set your own
    code (unless you reset the code to
    "0000").
    Press MENU to save the code.
    Hope this helps. :}
    HERE IS A LINK TO THE USER MANUAL:
    http://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
    Mar 31, 2008 | Philips Magnavox 27MS343S 27" TV
    Citizen house tv that has a 'lock' logo on screen
    The TV has been 'Locked'. To unlock it press the DISP button for 4 seconds. Since you have a universal remote and there is no way to determine which button is the DISP button try holding each button on the universal remote for 4 seconds until, hopefully, you find the correct one.
    Mar 10, 2008 | Televison & Video
    Tv is locked the screen is blue with a red padlock in the top corner
    my tv is locked & the screen is blue . how do you unlock it ?
    Nov 30, 2007 | Televison & Video
    My tv has been block.
    sounds like U have put the aprental lock on U will have to figure out how to take it off with the remote or at the panel buttons
    Dec 11, 2006 | Durabrand DWT2704 TV
    Televison & Video Logo
    161 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
