SOURCE: Sony DSC-W100 PROBLEMS
I found a solution that worked for me further on in this site. The person said to reset the camera. On my Sony DSC-W100, I opened the battery/memory slot door and to the left of the memory slot there's a tiny gray dot that I pressed and the problem has gone away.
SOURCE: flash does not work
Ok,
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
SOURCE: Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera
is broken, I checked online camera repair sites and also called Sony
directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix
CF card failure. Then my daughter said, "the CF card in my room works
fine in the camera" - and lo and behold - it does. The CF card that
works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT
work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice
is, before you give up on the camera as broken, try a number of
different CF cards first.
The second cause of CF failure is if
someone has pushed a CF card in the wrong way. That can bend one or
more of the tiny metal contact pins in the CF socket in the camera.
Look carefully to see that all the pins are straight up. [I don't know
how one can straighten these pins, or if the whole socket would need to
be replaced...but at least you can determine the cause of the CF
failure.]
Best regards - Michael
SOURCE: sony cybershot dsc t3
Please see the link below and consult any SONY SERVICE CENTRE nearby to you for free replacement of CCD IMAGER.
http://www.sony-asia.com/support/announcement/58200/product/dsc-t3
Thanks for using FIXYA!
SOURCE: My lense is stuck open despite turning my camera
This is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in this case, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of tuen ona nd off no longer shows(if it ever did) and the lens retracts and works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a sony tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay ad eventually cause it to stick. Hence the use of comptressed air with the brutal approach
