GE CTV MODEL 19GT300 CHANNEL SELSCTION PROBLEM
Gud day! i will ask something regarding my GE CTV MODEL 19GT300 the is is already tuned to channe 8 STD when the power switch ON. Push on th channel up button no transfer of channel still on 8. It can received/pick-up all channels using auto memory but selection of channel stop when reach channel 8 again it cannot transfer channel to lower or higher frequency. thanks in advance hope of you can help...god bless
Posted by ize_jaiz on
5 Related Answers
Anonymous
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
rallye
  • 23 Answers
SOURCE: GE 20GT320 TV
don't use auto programme.
use manual or semi auto.
you have to press the auto programme button a few times.
Posted on Jul 13, 2008
Anonymous
  • 14 Answers
SOURCE: motorola gp 68
Batlabs at http://www.batlabs.com/2way.html (Hand Held Radios) has the GP-68 users guide(Operation Guide), on the right side I think what you might be asking is in "Basic Operation 2", if not look into the Programming section below it.
Posted on Oct 30, 2008
Anonymous
  • 68 Answers
SOURCE: Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Posted on Jan 04, 2009
Anonymous
SOURCE: Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Posted on Apr 11, 2009
Describe how to program channels on lg tv
Very simple -
You will need to find a feature that says 'Auto Tune'
This first will ask you to select between:
1) Regular TV - off air antenna - connection
2) Cable TV - connection
3) DSS TV - Connection
If you aren't ready for digital TV with your antenna or cable you may get very few channels.
Nov 17, 2009 | LG 42LC2D 42 in. LCD HDTV
How do i tune tv channels into a sharp aquos tv lc19d1ebk
If I'm right in thinking this is a lcd tv with freeview already installed into it, you may not be on freeview,
What you need to do is: On the remote you have a button saying something like tv/digital or tv/dvs or something like this,
Press that so it goes onto freeview since you no need bother with analog tv anymore. Press the menu button and click installation, Will come up with tune channels or like that.
Go through the process and you should have all the channels in your area
Regards
Jul 25, 2009 | Sharp Televison & Video
No chann. 70 on Uniden 525 marine radio
You can't "select" channel 70, nor can you talk on channel 70. Channel 70 is reserved for the exchange of digital data between radios.
And it is not possible to address an "emergency" (do you mean distress? or urgency?) message to an individual recipient.
Your radio is not allowing you to do any of these things because it has been (correctly) programmed to discourage you from doing things that would be illegal.
If you set up a routine call with your friend (or anyone else), you should find that once the two radios have completed their (almost instantaneous) exchange on Channel 70, they will both switch to whichever working channel you had selected, and he will get a beeping sound to tell him that there is an incoming call.
Sounds to me like both radios are doing exactly what they are supposed to.
May 17, 2009 | Uniden Boating
No sound on some channels, words don't match mouth on some channe
you need to reset your TV settings. Happened to me with my 61" Panasonic LCD HDTV. Reset was under picture settings.
Jan 04, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
GE 27GT613 tv. has no video button
Use the remote to tune to channel 00. THis will give you the component inputs. The channel up down buttons will skip it so you have to actually push 00 on the remote.
Nov 17, 2008 | GE 27GT619 27" TV
How to tune AWA-Thorn C6337 television
There should be two dials, one is UHF, you need the main dial on U for the UHF channel tuner to work, turn the UHF dial with the main dial on U and if you have a UHF antenna, you should see something if you get a UHF broadcast where you are, the main dial will probably be numbered 0 1 2 3 4 5 6 6a 7 8 9 or something like that, they are VHF channels, should be preset at the factory, but if not, turn the centre of the main dial, you may have to push it in and turn.
In saying all that, i dont know the model, but im pretty damn sure it was the same or simular 63cm AWA Deep Image Colour set that i had from way back in the VERY early 80s. I cant remember that model number though.
Apr 20, 2008 | Televison & Video
Tv problems
I am assuming that you are using cable and not an aerial/antenna.
On your concern "...channels do not tune...correct channel numbers...", it is possible that when you re-tuned the TV your setting was set to AIR or STD, try to re-tune again but this time pls verify that you are in CABLE mode. If on the other hand you are using aerial/antenna, then it is the other way around.
Channel 0 would automatically be your Audio/Video (which is where your DVD/VCR is connected). If you re-tune, chances are that Channel 0 ) would be back. To be on the safe side, pls power on likewise the DVD/VCR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Mar 04, 2008 | Konka K1938U 19" TV
Operator manual for Mitsubishi CTV
Mitsubishi's TVs are much better their cars but some have a weird tuning system. Under the cover for AV3 input (lower right front of TV) is a small recessed button marked 'preset'. Push this, then choose 'Auto' to scan and load the channels then choose 'Manual' to adjust and reassign them to the right channels.
Oct 27, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
