AVCHD-Lite, which is a subset of the
AVCHD format popularized by hard disk camcorders from Sony, Panasonic, and
Canon, uses h.264 video coupled with AAC audio for recording movies. AVCHD Lite
video is currently used by Panasonic DMC-ZS3, Panasonic DMC-FZ3, Sony, Cannon
AVCHD Lite Camcorder, etc.
The main differences between AVCHD Lite and the regular
AVCHD: a maximum resolution of 1280 x 720p in AVCHD Lite compared to 1920 x
1080p in regular AVCHD and a less-intensive compression method - both of which
make the format more suitable for less powerful camera hardware.
What you need to burn AVCHD Lite to DVD on Mac OS
X?
Neither of AVCHD and AVCHD Lite video is directly
supported by iMovie or iDVD on Mac OS(10.6.3 Snow Leopard included) if you want
to
burn
AVCHD Lite to DVD. There are 3rd-party solutions that work with
varying degrees of success in allowing you to work with AVCHD Lite video on Mac,
like
Daniusoft DVD
Creator for Mac . It is DVD Burner that can convert AVCHD Lite video to DVD.
With it, you can add DVD menu, edit videos and pictures, add transitions and
effect, etc.
Below is the step by step guide on how to burn
AVCHD to DVD on Mac OS X
Step 1. Load files
Just click “+” button to import AVCHD Lite files to this
program or simply drag and drop them to it. And rearrange the file list by using
the up-down arrows.
Tips: You can freely drag and drop the thumbnail to merge
or split the video files.
Step 2. Edit files (Optional)
To personalize your DVD files, you can edit the video
files by clicking “Edit” button. For video files, you can crop the frame size,
trim into several clips, append effects, add picture/text watermark and
rotate.
Step 3. Create DVD Menu (Optional)
This Mac DVD Creator also allows you to create your own
DVD menu with rich selections of DVD menu template. Simply click “Menu” button
to select one and set the “Frame”, “Button” and “Text” to customize your DVD
menu.
Step 4. Start to burn
After all necessary settings, you need to insert a blank
or rewritable disc to your Mac if you want to burn video files on DVD disc. Or
you can simply convert the videos to DVD folder, .dvdmedia or ISO file on your
Mac for later burning.
That is it! Within several clicks, you can
burn
AVCHD lite to DVD easily. So, why not download Daniusoft DVD Creator for Mac
for a try?
