Question about Saitek P380 GamePad
My p380 analog control is effective when i go to control panel then to game controllers and do the test. but i am not sure how to use it to play games with?
Posted by marky_85 on
Anonymous
    New Friend:
  • 138 Answers
Some games will have joystick/game pad support while others will not you can try the joy2key utility for the ones that do not have direct game pad support
Posted on Jun 05, 2011
1helpful
I got the controller conected to my laptop, but the buttons wont work when i start playing the game, its a p380 dual analog pc gamepad
you must first make sure you installed the software drivers for the controller. when you open the game, make sure that you've setup the controller in your options window. your controller name should show up if done correctly. Note: in some cases, some games aren't compatable with certain controllers, i suggest that if this is the issue, you consider getting a better supported controller, preferrably a Microsoft 360 controller. they're cheap and wireless. Bam. Toaster streudel.
4helpful
4helpful
Hello There. Just bought a Saitek P380 Dual Analog PC Gamepad. Says on the box Certified for Windows Vista - Can it be used with Windows 7? Thank You. Billy.
I have not had too many problems with using stuff for vista on 7...If you want you can go to the microsoft website and see if your hardware is on the HCL(hardware compatibility list)
2helpful
Cant find drivers for windows 7
most of these devices they are not compatible with windows 7, no windows 7 software for this has been released as of this date.
2helpful
2answers
Ive just bought a saitek p380 dual analog gamepad. When playing all games if i press left it goes up and right it goes down. Ive tried everything. i have windows 7. Is that the problem do you think?cheers
it usualy the settings in the game. just try to reconfigure the x and y axes to do the right thing inside the game you are playing and that should solve the problem. i did it and it worked fine for me
regards.
Dmitry
Saitek 380 does not work properly with xp sp3
a lot of games need the xbox 360 controller i have encontered the same problem and i just use a xbox 360 controller
2answers
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
1helpful
I recently downloaded "Fallout 3" using "Steam" and bought the Saitek "P380 DUAL ANALOG" gamepad to play it with. A message appeared on my screen saying that the gamepad was installed and ready to use but...
XBOX360 Controller Emulator
http://www.tocaedit.com/IB/index.php?automodule=downloads&showfile=4
It helps. I got my saitek ps2700 to work with fallout3 with it. Yust download and install using instructions in readme.txt.
My dualshock 2 controllers analog are very hard. how to fix it
Hi warren111,
When you say hard, did you mean the controllers analog stick is very "stiff" or loose to the point that you can't move the characters onscreen or the characters move involuntarily. If this is your case then you may have to try another PS2 dualshock 2 analog controller in your PS2, If the problem doesn't happen with another controller, then you may consider buying a new PS2 dualshock 2 analog controller since most likely the controller is already defective.
Also try other games, see if the problem only happens with a particular game. If it does then you will have to check the settings of the game, and see if you can adjust the settings of the buttons or analog stick.
If the problem you're having is more with the "comfort" of the controller you're using then you should consider looking at 3rd party controllers for the PS2. One company that makes them is Logitech, they have a line controllers that work for the PS2 there are other companies so check out gaming sites to get reviews on them. But I would suggest though that if you're shopping for a controller because of this reason, you should try to test the controller out in a game shop first. So that you can get a feel of it before buying. If you like the controller and you're comfortable with it then tha's the time you buy it.
Hope this helps!
Peace! :)
Saitek P380 GamePad Logo
Top Saitek Video Game Consoles & Games Experts
Ekse
 TE5LA
TE5LA
ADMIN Canada
ADMIN Canada
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
